I got a Greddy/trust stainless manifold which had a custom manifold brace made from the T4 flange to the block to support the weight of the turbo, now Soon I'm ready to start fabricating the dump pipe and have herd some mixed opinions about solid mounting it and using a flexi joint.
I have herd to use flat bar to solid mount the dump pipe to the top bellhousing bolt then running a flexi joint after that to allow movement of the exhaust
Then ive herd people say to never solid mount the manifold or dump pipe just run the standard gearbox rubber hanger
What would be the best way to support and brace the dump to keep the weight off the turbo and manifold ?
https://www.sau.com.au/forums/topic/462021-turbo-manifold-dump-pipe-brace/
It should be fine to have the manifold and dump braced as you're suggesting. Just make sure there is a flex somewhere in the exhaust otherwise shocks to the system result in breakages of studs or worst case the manifold/dump.
Personally i wouldnt he constraining the manifold to the box. Sure support the weight off the head but if you constrain the dump then when e erything gets hot you woll be forcing it to grow in the opposite direction. Best support the weight then give it freedom to grow in whatever direction it chooses
I just had a look at mine, Im using the same manifold etc you are, with a TD06. My dump pipe has neither bracing NOR a flex joint. Manifold is not braced to block either. Manifold does however have small braces to prevent cracking etc
This exact turbo kit has been on my car for 2+ years, and has been on 2 cars previous to mine (R32 GTR and Driftsquid's S13 with RB25) plus whatever else before it. And before someone points it out, manifold flange was modded with 2 extra sets of holes, so fits RB25 and RB26.
Not one single issue whatsoever. No broken studs, no issues with dump pipe etc, I do however use new rubber exhaust hangers, and put new studs and gaskets in when turbo kit went on, but thats it.
The setup ive run on my track car with good sucess steam pipe mani no brace, flex joint in dump when it comes off turbo going down then a support for the dump at the flange to exhuast but not completly solid alowing play just enough to hold its weight.
I was also thinking about thermal expansion when you brace too much, which may cause more issues as it cannot expand
The brace from manifold to block is free to move as the manifold expands, I was just wondering about bracing the dump,
I may make the the dump pipe with a flexi joint and just run the factory gearbox rubber mount, should be good enough
One of these!
3BFA8BA2-503F-4AA5-B87E-4D646D23C170_zps
50BBC131-1F45-4F97-85A1-24CEEDF5718E_zps
Yep just got one ! 4" stainless flexi joint for the dump
Would take a lot of stress off the manifold as the exhaust shakes and Carrys on during driving
You still running the gearbox exhaust mount which bolt to the cat flange (decat lol) ?
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
