Update managed to pull injectors and rail turned car over with injectors plugged in and facing in the air all appear to be spraying equally :angry: any ideas throw them my way please :action-smiley-069:
Ideally at this point you would send the injectors away for cleaning and testing but otherwise you could at least swap out no 6 with another injector and see if the problem moves or stays at no 6
  • Like 1
good call i will try that first as for cleaning if i can move the issue with swapping injectors i will upgrade the oem ones :) thanks i will report back tonight
not yet pal although i think i will tackle the more likely candidates i think 6 runs intermittently due to number 6 manifold instantly evaporating water on a cold iso start unless the intake cam has gone and there is enough vacuums to partially draw through some of the mixture on 6 just seams unlikely and the valve train is almost silent at low idle just hear the injectors i will get the new spacers on tomorrow and test things out see if it moves swapped 6 and 1 injector to see if the problem moves :)
All assembled and the issue stays at 6 also another thing coming back from the test drive and this has happened before video attached best explains the issue please note the backfire and also the soot
plus the engine dose run smoother than this regardless of 6 being out of action
http://youtu.be/ilUMXeQUqMQ
It would be unlikely that the ecu is to blame but would be good to eliminate it if you had another known good one to swap out.
Actually would be worth checking the pins - pull the ecu plug out and have a good look at the plug and socket.
i will have a look tonight pal :) my friend with a top of the range diagnostics computer will be trying to get codes for me for both this issue and the abs issue
just to confirm again 6 is defornetly down after idling for about 5 mins i could grab No.6 manifold runner
now this is just a thought but if say 6 intake cam was snapped could the fuel from 6 injector pool and run into 5 causing the sooting and popping or is that a bit far fetched ?
as for ecu i should have mentioned that i had attempted to install a ecu master det 3 piggy back after playing with the settings for a bit trying to get it to adjust fuel settings it ran fine then boom i shut it off and it wouldn't start again so i removed the set 3 from the loom at the ecu plug end and still no fire up so i pulled all plugs and dried them out and cylinder by cylinder it splutters back into life (please note that there has always been a misfire and idle issues ).
Just dive in man and get those cam covers off and see what's going on. Make sure everything looks normal and put a ratchet on the balancer bolt and turn the motor clockwise by hand and check everything turns as it should.
If there is nothing obviously wrong it should only take an hour and a bit all up including putting it all back together.
will do tomorrow afternoon i will start
also on a side note some f**kwit appears to have cut the consult diagnostic port of ? well its not there anymore :( after my mate got his computer out as well ! is there a way of getting a pinout for making my own ? or should i just install a fresh unmollested loom remove all the boges ?
still not given up been researching and found that timing out a tad and possible poor fuel flow caused by pump or fuel pump 12v feed apparently voltage drops as idle so common cure is constant 12v feed through relay also I'm changing timing belt and ancillary belts while I'm at it also converting from visco fan to 12v
Edited by centoproject
Fan conversion a retrograde step in most cases.
right i will stick with it then on other updates found a boost leak on all injectors upon removal of the rail i had noticed that the vac line for the fpr smelt like fuel could this be my problem all along poor or intermittent fuel flow/pressure waiting for serpentine belts then i will re assemble along with the disco fan :yes:
having changed and timed the engine serviced all of the belts ect 6 is still dead sprayed water on manifold from spay bottle and 6 runner hardly evaporated so timing is out of the question starting to think its somewhere in that loom still getting spark ect fuel volume is identical to other 5. so frustrating..... is this the most problematic stagea ever ?? determined to get it sorted ! may go full aftermarket ecu and new engine loom.. may look into spark plugs next go more basic...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
