Update managed to pull injectors and rail turned car over with injectors plugged in and facing in the air all appear to be spraying equally :angry: any ideas throw them my way please :action-smiley-069:
Ideally at this point you would send the injectors away for cleaning and testing but otherwise you could at least swap out no 6 with another injector and see if the problem moves or stays at no 6
  • Like 1
good call i will try that first as for cleaning if i can move the issue with swapping injectors i will upgrade the oem ones :) thanks i will report back tonight
not yet pal although i think i will tackle the more likely candidates i think 6 runs intermittently due to number 6 manifold instantly evaporating water on a cold iso start unless the intake cam has gone and there is enough vacuums to partially draw through some of the mixture on 6 just seams unlikely and the valve train is almost silent at low idle just hear the injectors i will get the new spacers on tomorrow and test things out see if it moves swapped 6 and 1 injector to see if the problem moves :)
All assembled and the issue stays at 6 also another thing coming back from the test drive and this has happened before video attached best explains the issue please note the backfire and also the soot
plus the engine dose run smoother than this regardless of 6 being out of action
http://youtu.be/ilUMXeQUqMQ
It would be unlikely that the ecu is to blame but would be good to eliminate it if you had another known good one to swap out.
Actually would be worth checking the pins - pull the ecu plug out and have a good look at the plug and socket.
i will have a look tonight pal :) my friend with a top of the range diagnostics computer will be trying to get codes for me for both this issue and the abs issue
just to confirm again 6 is defornetly down after idling for about 5 mins i could grab No.6 manifold runner
now this is just a thought but if say 6 intake cam was snapped could the fuel from 6 injector pool and run into 5 causing the sooting and popping or is that a bit far fetched ?
as for ecu i should have mentioned that i had attempted to install a ecu master det 3 piggy back after playing with the settings for a bit trying to get it to adjust fuel settings it ran fine then boom i shut it off and it wouldn't start again so i removed the set 3 from the loom at the ecu plug end and still no fire up so i pulled all plugs and dried them out and cylinder by cylinder it splutters back into life (please note that there has always been a misfire and idle issues ).
Just dive in man and get those cam covers off and see what's going on. Make sure everything looks normal and put a ratchet on the balancer bolt and turn the motor clockwise by hand and check everything turns as it should.
If there is nothing obviously wrong it should only take an hour and a bit all up including putting it all back together.
will do tomorrow afternoon i will start
also on a side note some f**kwit appears to have cut the consult diagnostic port of ? well its not there anymore :( after my mate got his computer out as well ! is there a way of getting a pinout for making my own ? or should i just install a fresh unmollested loom remove all the boges ?
still not given up been researching and found that timing out a tad and possible poor fuel flow caused by pump or fuel pump 12v feed apparently voltage drops as idle so common cure is constant 12v feed through relay also I'm changing timing belt and ancillary belts while I'm at it also converting from visco fan to 12v
Edited by centoproject
Fan conversion a retrograde step in most cases.
right i will stick with it then on other updates found a boost leak on all injectors upon removal of the rail i had noticed that the vac line for the fpr smelt like fuel could this be my problem all along poor or intermittent fuel flow/pressure waiting for serpentine belts then i will re assemble along with the disco fan :yes:
having changed and timed the engine serviced all of the belts ect 6 is still dead sprayed water on manifold from spay bottle and 6 runner hardly evaporated so timing is out of the question starting to think its somewhere in that loom still getting spark ect fuel volume is identical to other 5. so frustrating..... is this the most problematic stagea ever ?? determined to get it sorted ! may go full aftermarket ecu and new engine loom.. may look into spark plugs next go more basic...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
