Malakai Posted February 14, 2016 Share Posted February 14, 2016 Might be time to drop some dollars on a diagnosis by a good mechanic. Link to comment https://www.sau.com.au/forums/topic/462025-number-6cl-keeps-dropping-out/page/3/#findComment-7683277 Share on other sites More sharing options...
centoproject Posted February 15, 2016 Author Share Posted February 15, 2016 right 6 i seemingly back reading further into the mines ecu it seams that it is tuned for jdm grade fuel around 100 ron ? so i found a fuel supplier claiming 99.9 ron cleaned number 6 plug and started it sprayed with water again and 6 is evaporating same rate although after coming back from the trip i have found that 6 is seemingly not evaporating as quick also re installed recirculation valve witch has cured stalling at the lights but when i had returned home i found the return line had blown off so hopefully that had caused the rich mixture to flood the plug Link to comment https://www.sau.com.au/forums/topic/462025-number-6cl-keeps-dropping-out/page/3/#findComment-7683973 Share on other sites More sharing options...
centoproject Posted February 26, 2016 Author Share Posted February 26, 2016 Right not to leave a thread without a conclusion 6 is back and strong just abs fault to go cause was a tiny carbon trace burnt into the ceramic therefore failing to spark properly on 6. thanks for those who threw ideas out Link to comment https://www.sau.com.au/forums/topic/462025-number-6cl-keeps-dropping-out/page/3/#findComment-7689529 Share on other sites More sharing options...
