MMmm ok, I bought this car with a 3 inch straight through already on it.
It has the large twin tip Jasma muffler.
As much as I'd hate to say it , it's just too loud.
Giving me a headache with every day driving.
I reversed up a steep driveway early last Saturday and woke up the whole street.
The deep growl at low rpm is awesome, but mid range ..... :yucky:
There's a crackle that just echoes off everything I pass.
So can anyone suggest a muffler that will have minimum loss of power, no drone and still a nice sound.
Forget Varex Xforce, aint gonna waste $500 on a muffler..., plus extra $$ on install
cheers
https://www.sau.com.au/forums/topic/462026-m35-performance-exhaust/
Fujibitsu legalis R is by far the best system. Straight bolt up proven to flow over 300kw atw and a nice sound with absolutely no drone and is legal volume. If you get one and need it fitted bring it over and I'll bolt it up.
^What he said
I swapped my stock variable system for a Fujitsubo and made a huge difference and highly recommend it.
If you are interested in my old system I'm happy to sell it. It's a factory variable system
Mine looks the same as Luis.
What's the deal with the second mid muffler ???
Does is act as a resonator or something ?
I'll put it up on ramps and take some pics tomorrow..
Thanks Josh for the offer mate
Edited by conan7772
I'm assuming twin tip is louder than single.
Twin tip is designed to flow faster ??? Less time for sound to be absorbed..
I think my muffler is slightly larger than Luis and completely hollow.
I put a stick in there and couldn't feel a thing.
I'll take some measurements tomorrow and db test it.
Edited by conan7772
Mate the varex systems are way too loud when open and so restrictive when closed. These engines have such loud low rev engine sound and its hard to make an exhaust that is not loud.
Ive had aa apex-n1, straight through with varex, fujitsubo legalis r and now a kakimoto hypermega and have to say that the fujitubusu legalis is the quietest followed closely by the kakimoto hypermega n1. If you can get your hands on either of these systems you will be more than happy.
Loudest system ive had is the apex-i N1. This thing can be heard from like 4 streets away.... stupid loud
Edited by joshm35
This is my old system next to my new one
This is actually a stock V35 coupe mid section joined to the stock M35 rear muffler... The stock V35 sedan/M35 Stagea is about 10 times bigger...
It is a cheap change quick change over that is a tonne lighter and does make it sound a little bit nicer than stock... And yes, I did this mod... :-)
I wondered why the mid pipe always looked different to other stock M35's exhausts I have seen. How was the droan compared with the V35 mid section after you swapped it
There was none...
Was able to use bluetooth device clipped to sunvisor without any problems before and after changing the mid section. I ran it with the coupe mid section for a couple of years and around 25,000km. Sold the car with it, and pretty certain that the guy who bought it also left it on there.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
