Yep I have the same identical exhaust as Luis, the Fujitsubo
Legal my arse..
I have that exhaust with Scottys dump and 100 cell cat there is no way it is that loud. You can hardly hear it until i am well and truly up it.
Have you conducted your test in accordance with the RMS specs, and ensured that there are no hard surfaces within 20 metres to reflect any sound?
There is no way the Legalis is 114db.
Legal my arse..
I have never heard a Fujitsubo get that loud.
I ran one on my previous M35 with an intake & dump pipe from Scott as well as a Kakimoto de-cat front pipe.
No chance in hell it hit 114db
My current VQ35 under full throttle with only the headers attached, sure.
I did the test at 5000 rpm, and the device was 1m away sitting on the driveway.
Exhaust was facing the street to so no reflecting surfaces.
I get 75 db inside the cabin.
With the windows down I get 85 db
Device is calibrated and gets normal conversation at 65 db so it's pretty good.
One thing... my cat is a single cell , if you get my drift
I'll get a 100 cell bullet cat, that should quiet it down a bit.
Also don't like the explosions of unburnt fuel on freeway driving.
This is what I have now.
Edited by conan7772
Thats a big suprise as i was suprised how quiet my Kakimoto Hypermega N1 is. Ill try and get cabin / exterior sound clip when i can. I also have the 62mm kakimoto silencer that can quiet it even more with no restrictions due to same internal diameter
Yeah but it will be loud and drony if made.
"if made badly or ignorantly"
I am getting a new exhaust made in the next few weeks. I'll try and post up how it sounds when done. I guess i could have just gotten a new dump / flex and joined the Fujitsubo crew but i like tackling things my own way with what i have at my disposal locally. Support the locals folks :)
If the bloke i am using's other work is an indication of what i'm in store for it should be a nice bit of kit.
  • Like 1
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
