Yes that rasp and the volume does seem to indicate a complete absence of any baffles and sound absorbing materials... The sound is litterally just bouncing around the pipes...
Certainly explains the touchy throttle with no restriction.
When I had the stock turbo, I'd be on boost reversing up driveways.
100 cell cat fitted today as there was none, a tad quieter but not much.
Less rasp. Next to zero loss in performance.
The mufflers looks as new, no evidence of cutting open or modification.
I did a poke inside the rear muffler to feel for baffles and/or walls.
It appears completely hollow.
It's looks the same system as Luis.
The previous owner told me he went for a straight through option on the exhaust.
Anyway, still have AMPerformance intake to stick on, then tune. Probably be louder again.
  • Like 1
Intake will change bugger all.
It's already metal; all you're doing in putting a bigger pipe down to the same inlet restriction.
  • 1 month later...
  • 3 months later...
Is that for the 2.5 and 3.5 litre motors ? My flanges are badly rusting and figure I'll be needing to do something soonish and I've got the 3.5...
All NM35 (VQ25det) cat-back exhausts will fit a PNM35/PM35 (3.5L) without modification.
The M35 (VQ25dd) utilises different hangers for the rear muffler for whatever reason.
  • Like 1
  • 1 month later...
ok sorry revisiting this again.
People are constantly commenting how loud my car is so back to work on it.
My exhaust is Legalis R, twin 83mm tips. Fujitsubo stamp on the rear muffler
Rear muffler is straight through with a perforated inner skin. (Boomer)
I can see the inlet with a torch.
Internal outlets look 50mm then flare to 83mm
Can anyone confirm this is the genuine design for this system ?
Thinking of fitting a chambered rear if it won't be too restrictive..
thanks
Are these car people or just general population?  As someone not into cars may think anything louder than a prius is too loud.
It's possible yours may have been modified as I have a freeway dolphin dump and front pipe, into a fujibutso legalis R and it's very quiet a full turbo back 3inch. I also have a 7m powered soarer with 3inch kakimoto exhuast which sets off car alarms it's so loud in comparison.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
