Im not discrediting their work, i am letting you know from my experience (take it or leave it). Im all for supporting local business but just giving you the heads up these vq low rev engine sounds are bloody loud (especially in the cabin) where you will be on a constant dose of panadol for the headaches.
I have spoken to one of the local m35 owners here in brisbane about his experience and he mentioned he changed to a diesel muffler and had it sticking out a little more from the rear of the car so the exiting noise was past the rear of the car not under it. Happy trails with you're shop just food for thought.
You're comment sounded like me a few years ago. Now i have a exhaust that was made for the nm35s.
I always appreciate the information and opinions.
I ran an N1 exhaust first on my M35 but went fully custom due to the drone and have had custom for the last year and a half. Compared to what i have heard on youtube clips etc i would hardly call mine droney or loud in comparison but then again my experience with M35's is fairly limited to 3 owners cars.
I may regret not going for a Fujitsubo this time but i'll try and post a clip once mine is sorted for science.
Diesel mufflers are pretty much larger cylinders with a perforated hole pipe that's straight through. Some glass packed or not. Most of the mufflers off the shelf have baffles or loops inside (don't get me started on bullets and cobys). Effectively just makes it like the branded ones without the label price. Cut one open
Edited by Reaperblitz
"if made badly or ignorantly"
I am getting a new exhaust made in the next few weeks. I'll try and post up how it sounds when done. I guess i could have just gotten a new dump / flex and joined the Fujitsubo crew but i like tackling things my own way with what i have at my disposal locally. Support the locals folks :)
If the bloke i am using's other work is an indication of what i'm in store for it should be a nice bit of kit.
You'll have much less of an issue with the drone situation with the manual conversion; which is yet another good thing to add to the enormous list of good things about manual cars... :cheers:
  • Like 2
I have Bricks intake now.
Haven't fitted yet, gees imagine would probably be over 120db.
Video coming soon of my Fuji with single cell cat.
My work associate said he could hear me for a good minute before I pulled up to site.
I like the look of that silencer, looks smart.
If the new cat doesn't bring it down enough I might try one of those.
That doesn't sound like any Fujitsubo I have heard under load.
Does it look like it has been tampered with? Resonator still intact? Maybe the rear muffler has been gutted of the baffling by the previous owner?
  • Like 1
I was going to say; mine sounds nothing like that.
That has a rasp that is completely absent from mine.
Is there a cat fitted?
With a sound meter phone app (no guarantee of accuracy) mine only registered 90dB at peak (free rev).
But even allowing for error; there's no way known that it would be 107dB, I have mates with bikes around 104dB, and they are orders of magnitude louder than my quiet ol' Fuji.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
