S A U N S W Trackschool Trackday 20th April Round 1 Club Championship
Yup, A1RM is a good street pad and ok for light track work. Unfortunately, Wakefield has three big braking spots that makes it a bit hard on brakes for heavy cars. But then again, tyres also will control the amount of braking you get so may balance out if on street tyres.
A1RMs are fine in a car with less than 200rwkw, you're just not pulling down as much speed. I never had issues with brake fade with them but the caveat to that is that I flush my brake fluid regularly.
  • Like 1
So the last 2 days the cam seals and turbo water feed have been replaced due to leaks. Then my timing belt tensioner decided to let go and the belt jumped a toothed, luckly it didnt bend a valve.
New tensioner will arrive tomorrow, hopefully early.
Breaks and tires are still good, just need to mount the fire extinguisher again and fill up the jerry cans.
​SAUNSW Track Championship information.
If you are an SAUNSW financial club member and want to get your points for this round,
If you don't see your name below, Please PM me your Full Name and Forum Name.
Thankyou.
SAUNSW Championship Entries.
Will update Championship entry as received.
1. Aggroman
2. GTofuS-T
3. Pezhead
4. Bodella
5. Fatz
6. RiseofBrutality
7. deongster
8. wagon_boy
9. kila32
10. stagea_pete
CV joint fixed , new project Mu pads in the front, used a1rm's in the back and fresh fluids all round. Front near side strut making clunking sound, let's see if I can break it completely. also running Pirelli Cinturato P1, so I have I built in excuse for poor times.
Cool Ryan, haven't seen you in Yonks!
Reunion Texi Trackday?
Where are Cassbo, Liz, Doof, etc
(Edit - Eric, learn to read thread titles when SAU'n at work!)
Indeed mate, looking forward to tomorrow, last year was very long year with 0 motorsport, . Also looking forward to talking shit with people.
Anyone staying in Goulburn on the Wednesday night?
Anybody ?
Excellent day guys. Always fun to talk shit in between sessions!
Pretty happy with beating my PB by 2.5 seconds with no changes to the car (and the same shitty tyres I've done my 4 previous track days on), the list of want-to mods just keep going.
Well done guys - real shame i had to pull out on Monday - my Son got admitted into the hospital for RSV on Sunday night being less than 6 months old - was a bit worrying - i figured its more important to be closer to home... im glad everyone had fun!
Till the next one!
You priorities are in the right place Des. Hope he's all better real soon.
Much better. Still has that congestion sound. But much better. [emoji4]
  • 3 weeks later...
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
