89CAL Posted January 6, 2016 Share Posted January 6, 2016 I run 23psi with splitfires and 0.8mm gap. Good times They will do till they break Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662563 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 6, 2016 Share Posted January 6, 2016 I run 23psi with splitfires and 0.8mm gap. Good times They will do till they break I find they're ok on the dyno whilst I'm tuning, great for street use.. as soon as I hit the track and do a few laps.. bamm misfire city! But at 0.5mm it's tits.. no misfires at all!!! 1 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662566 Share on other sites More sharing options...
deprived777 Posted January 6, 2016 Author Share Posted January 6, 2016 i got a reply from the guy on ebay that sold me that coilpacks: The coils are brand new too though.You need to confirm there are no other underlying issues with the car, such as: - Ensure that the coils are mounted and plugged in properly and the rubber boots are seated correctly and the springs are making good contact with the spark plugs. (This is the most common cause for a misfiring coil pack).- Check that the coil wiring loom isn’t old and brittle or faulty.- Check the CAS (Crank Angle Sensor) as it may be faulty.- Check the TPS (Throttle Position Sensor) as it may be faulty.- Check the AFM (Air Flow Meter) / MAF (Mass Air Flow) meter as it may be faulty.- Even the ECU settings may affect how the coils operate. Please ensure the ECU you are using does not need to be retuned or reset to accommodate the new coil packs. now i know the coil packs are definitely on properly,wiring loom is good, but not sure on the other things but i would assume that would of been checked over while tuning. So what do i say in reply ? Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662611 Share on other sites More sharing options...
Ben C34 Posted January 6, 2016 Share Posted January 6, 2016 Write "f**k you" 2 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662631 Share on other sites More sharing options...
GTSBoy Posted January 6, 2016 Share Posted January 6, 2016 Well, this is why your chances of getting a refund on these coils is a bit slim. The term is "caveat emptor". Not doing your research on the suitability of a product before buying it is a mistake. When the product gets installed into a system where the product itself could be faulty, or any of a dozen other things could be faulty, then convincing the seller that the product is at fault is a difficult task. We all pretty much know that they are going to be at fault, regardless of the possibility of other causes. You either run through and do every one of the checks that that seller asks you to, and then tell him the results, or you tell him a porky, say that you have done the tests, and have even swapped out the coils with a friend's Splitfires/new OEM coils and it runs properly with the other coils in it. The end result of doing the former is that you might still not convince him or yourself. The end result of telling the fib is that you might get him to agree to take the coils back and all will be right with the world. 1 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662632 Share on other sites More sharing options...
75coupe Posted January 6, 2016 Share Posted January 6, 2016 My lawyer checked all the ACCC contacts and they arnt faulty Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662633 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 6, 2016 Share Posted January 6, 2016 Typical BS... just plug up a set of OEMs or Splitfires and your misfire will go away.. that proves straight away the coils are shit and nothing else is stuffed. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662638 Share on other sites More sharing options...
Daz Posted January 6, 2016 Share Posted January 6, 2016 Yellow Jackets belong in the bin Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662640 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 6, 2016 Share Posted January 6, 2016 Yellow Jackets belong in the bin They're like Dick Smith shares that were heavily inflated... Buy today, then sell 80% less tomorrow.. wait there's a trading halt.. so bin it is lol 1 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662674 Share on other sites More sharing options...
GTSBoy Posted January 6, 2016 Share Posted January 6, 2016 To be fair......Yellowjackets have their place. It's just that it's the bin! 2 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662678 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 6, 2016 Share Posted January 6, 2016 a good read.. with data to back it up http://www.sau.com.au/forums/topic/421392-dont-be-fooled-into-buying-cheap-coil-packs/ Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662684 Share on other sites More sharing options...
GTRPSI Posted January 6, 2016 Share Posted January 6, 2016 If bought on ebay my advice is to test with a known working set of coils and if the issue goes away let him know, if he does not play ball, start a ebay/paypal dispute....when that fails go to consumer affairs. Once consumer affairs gets involved he will have a headache at hand, 9 out of 10 times they side with the consumer. I know because i had a customer buy a Exedy clutch kit, he dropped the clutch cover while fitting it onto the ground (bent corner of pressure plate cover with concrete dust still on it) and consumer affairs still said its my problem...eventually exedy agreed to take it back stating that from experience consumer affairs generally finds against the supplier and manufacturer regardless and its not worth their tech team and my time attending mediation meetings, and they already have washed into the price for these things to happen. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662693 Share on other sites More sharing options...
Daz Posted January 6, 2016 Share Posted January 6, 2016 They're like Dick Smith shares that were heavily inflated... Buy today, then sell 80% less tomorrow.. wait there's a trading halt.. so bin it is lol Another once decent aussie company down the shit hole Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662714 Share on other sites More sharing options...
deprived777 Posted January 6, 2016 Author Share Posted January 6, 2016 i think my best bet is to email trent and ask for some help if he's got time.im sure all of that stuff would of been checked while tuning ? if i had other coils to try i would do it right now and im 99% positive there would be no misfire. tomorrow i'll be taking out the plugs and ill take it to someone to gap them properly for me and see what happens Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662739 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 6, 2016 Share Posted January 6, 2016 i think my best bet is to email trent and ask for some help if he's got time.im sure all of that stuff would of been checked while tuning ? if i had other coils to try i would do it right now and im 99% positive there would be no misfire. tomorrow i'll be taking out the plugs and ill take it to someone to gap them properly for me and see what happens gap them yourself bruh! if they're copper, just slot in a feeler gauge and tap the tip with a small meta object.. I'm a lazy prick, so I just bang mine against the radiator support.. works a treat. 1 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662755 Share on other sites More sharing options...
admS15 Posted January 6, 2016 Share Posted January 6, 2016 I just tap mine against a brick wall. 2 light taps, they go from .8 to .65. Ive got it down pat, I almost don't even need a feeler. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662763 Share on other sites More sharing options...
tridentt150v Posted January 6, 2016 Share Posted January 6, 2016 I use the pedestal vice in my shed, but anything will do it, then squeeze a feeler gauge in and see how you go. Basic feeler gauges are cheap, tools are minimal, so no excuses. And learn as you go..... 2 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662766 Share on other sites More sharing options...
deprived777 Posted January 6, 2016 Author Share Posted January 6, 2016 alright alright lol i'll get a feeler gauge tomorrow. i guess its something i do need to learn for myself Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662808 Share on other sites More sharing options...
Trex Posted January 6, 2016 Share Posted January 6, 2016 dont get me started on YJ's and performance China Racing wise lol. I think a few of you saw the shit storm on some of the products I and a few others had bought which do not fit. Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662809 Share on other sites More sharing options...
Trex Posted January 6, 2016 Share Posted January 6, 2016 alright alright lol i'll get a feeler gauge tomorrow. i guess its something i do need to learn for myself its extremely easy mate, and a good tool to have. You need to check each plug when buying new, as always 2/6 plugs i have bought have been out by a least .5-1.0 Link to comment https://www.sau.com.au/forums/topic/462048-just-had-my-r33-tunedbut-now-its-misfiring-quite-bad-yellow-jacket-coil-packs/page/2/#findComment-7662811 Share on other sites More sharing options...
