to me replacing them is more hassle and seems a waste of time if they're going to keep failing
yep... I did that twice, then I it started to misfire again and I was like fuark this... I'm buying Splitfires.. so I did.
Ended up selling my YJ for $100 LOL
The yellow jackets (or even just one of them in your set of 6) are not necessarily "faulty". They're just not necessarily good enough for the duty they're being asked to work in. As replacements for stock coils which have died, on stock engines, most people would not have much cause to question their quality. As replacements (or "upgrades"!) in engines being pushed a lot harder, you will get some people like Ravi who report no problems, some people who report that they just break down and won't make power, and others who report that they they just die. I interpret this to mean that they are not powerful enough in general, and the quality is variable. Seems enough of a reason to pick something else if given the choice.
  • Like 1
^ Well said. Standard engine, standard turbos, standard manifold pressure (12psi max), in my experience they work fine. Once you start leaning on them, I don't think any China coils will handle it.
Works fine for what it costs as a standard replacement. Don't know why people who want to push 20+psi and want to make 300rwkW think $300 coils will be as good as $700+ ones.
Sort of like asking standard turbos to push 15+ psi.
I had (second hand) yellow jackets on 23psi with 0.8mm gap for years without a issue.
Dont know why they dont work for others......
update on the ebay dude:If it is a faulty coil then it would only be 1. It wouldn't be all 6 at the same time.
This alone is an extremely rare occurrence as a lot of care goes into these coils during the manufacturing process.
We will need isolate the single faulty coil though so it can be replaced under warranty.
Thanks.
whats my reply going to be ? should i go for replacements or keep insisting on a refund. to me replacing them is more hassle and seems a waste of time if they're going to keep failing
If it were me, I'd isolate the faulty coil and try to sort out a warranty claim. At least you will get something for free. In the meantime I would plan to get some splitfire coilpacks. Drive it around normally on the yellowjackets, put the splitfires in then get it tuned. I can't remember if it was a daily driver, but mine is so I would do that to keep it mobile so I can at least get places
Sometimes you can test the coils by unplugging them one at a time with the car idling, listen for a noticable change in the engine note/revs, that generally means you've unplugged a good coil (as removing it from the system has made the performance worse)
However, if it only plays up under higher loads then this probably wont work. I did this test with mine and noticed change in engine note on 2 cylinders from memory, but mine played up at idle. Because I was never going to get warranty, and didn't want to risk more failing, I just replaced them all with new splitfires
Buying new coils then having some sitting there doing nothing while also possibly paying for a new tune as it was not the tuners fault. It's all adding up.
I'd be pushing for a refund and explaining the position they have put you in. Might be worth while getting in contact with a fair trade ombudsman.
Also if you paid via paypal contact them with your predicament.
It was paid using PayPal so that sounds promising. I responded to the guy saying u would prefer a, refund and he just replied I can replace the faulty coils. Cheeky prick lol.
I gapped the plugs down to 0.6mm and the misfire improved alot. But it feels like it's lacking a bit down low now. Car only was misfiring under heavy load on 18psi otherwise it was fine. So not sure how I would test the coils. What a pain. I'll have to keep insisting
do a paypal dispute.
Takes way too long figuring out what coil is bad.
I responded again saying I much rather a refund and explained the reasons why and that I had spent alot getting it tuned and will have to again etc.see what he says this time. If he doesn't agree I'll look into the PayPal dispute thinh
While not defending yellowjackets (I run splitfires).
What does the product claim to do? I just did a quick google and found this description from a dealer
Increase in torque.
- No spark blowout at higher boost.
- Improved throttle response and smoothness.
- Increased Ignition Performance.
- Improved Combustion.
- Direct Fit.
- 2 Year Warranty.
- Solid Construction.
- Cost effective.
Unsure if you have a basis for a refund, unless of course you could do a back to back with another brand, but even then, claims such as "no spark blow out at higher boost" leaves it wide open, what is high boost? 12psi? or 24psi?
Anyways, you could persist, or just realise they are known (by doing an hour research) to not work that well, and move on.
Don't forget you have a limited window to initiate a Papal dispute, like 45 days after purchase or something??
As CEF33Y pointed out it's so vague, do these things even have a spec sheet? do Splitfires? Interesting to see if there's a design difference or if it's just quality variability.
also.. I would measure your voltage across RPM for your car..
I had a faulty alternator that would drop to about 12.2 volts at 4~5k rpm.. I have a brand new Circuit Sports one and it holds 14V to Redline :)
However, that's another story.
I'll take it for a drive soon. But as far I know it's above 14k all the time according to the power fc Hand controller. I bought the coil packs November 6th. So that 45 days with PayPal is out the window I guess. Got another reply and he said he will only replace the faulty coils
Edited by deprived777
in regards to repair replace or refund legalities.
https://www.accc.gov.au/consumers/consumer-rights-guarantees/repair-replace-refund
you have a major problem and are entitled to a refund. the refund must come from the retailer who sold you the defective product. and if he gets snarky, you can take them to small claims court for damages and loss, so you can get your money back for the tune.
had a quick read through that.and to me it would fall under a major problem so i think i should be able to get a refund.
he just replied again and said he wont refund them and i mentioned that in his ad they mention no spark blow out at high boost and satisfaction garunteed and throttle response ( which has gone down now after gapping plugs lower)
I told him about accc and strongly insisted on a refund and all he replied was, I can only offer an exchange under warranty. This complied with consumer law in Australia.
So I guess I'm stuck. Maybe I'll just get a new set of 6 and try sell them and buy splitfires. Such a stuff around. Guys a jerk
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
