I run 23psi with splitfires and 0.8mm gap. Good times :)
They will do till they break
I find they're ok on the dyno whilst I'm tuning, great for street use.. as soon as I hit the track and do a few laps.. bamm misfire city!
But at 0.5mm it's tits.. no misfires at all!!!
  • Like 1
i got a reply from the guy on ebay that sold me that coilpacks:
The coils are brand new too though.
You need to confirm there are no other underlying issues with the car, such as:
- Ensure that the coils are mounted and plugged in properly and the rubber boots are seated correctly and the springs are making good contact with the spark plugs. (This is the most common cause for a misfiring coil pack).
- Check that the coil wiring loom isn’t old and brittle or faulty.
- Check the CAS (Crank Angle Sensor) as it may be faulty.
- Check the TPS (Throttle Position Sensor) as it may be faulty.
- Check the AFM (Air Flow Meter) / MAF (Mass Air Flow) meter as it may be faulty.
- Even the ECU settings may affect how the coils operate. Please ensure the ECU you are using does not need to be retuned or reset to accommodate the new coil packs.
now i know the coil packs are definitely on properly,wiring loom is good, but not sure on the other things but i would assume that would of been checked over while tuning.
So what do i say in reply ?
Well, this is why your chances of getting a refund on these coils is a bit slim. The term is "caveat emptor". Not doing your research on the suitability of a product before buying it is a mistake. When the product gets installed into a system where the product itself could be faulty, or any of a dozen other things could be faulty, then convincing the seller that the product is at fault is a difficult task.
We all pretty much know that they are going to be at fault, regardless of the possibility of other causes. You either run through and do every one of the checks that that seller asks you to, and then tell him the results, or you tell him a porky, say that you have done the tests, and have even swapped out the coils with a friend's Splitfires/new OEM coils and it runs properly with the other coils in it. The end result of doing the former is that you might still not convince him or yourself. The end result of telling the fib is that you might get him to agree to take the coils back and all will be right with the world.
  • Like 1
Typical BS...
just plug up a set of OEMs or Splitfires and your misfire will go away.. that proves straight away the coils are shit and nothing else is stuffed.
Yellow Jackets belong in the bin
They're like Dick Smith shares that were heavily inflated... Buy today, then sell 80% less tomorrow.. wait there's a trading halt.. so bin it is lol
  • Like 1
If bought on ebay my advice is to test with a known working set of coils and if the issue goes away let him know, if he does not play ball, start a ebay/paypal dispute....when that fails go to consumer affairs.
Once consumer affairs gets involved he will have a headache at hand, 9 out of 10 times they side with the consumer.
I know because i had a customer buy a Exedy clutch kit, he dropped the clutch cover while fitting it onto the ground (bent corner of pressure plate cover with concrete dust still on it) and consumer affairs still said its my problem...eventually exedy agreed to take it back stating that from experience consumer affairs generally finds against the supplier and manufacturer regardless and its not worth their tech team and my time attending mediation meetings, and they already have washed into the price for these things to happen.
i think my best bet is to email trent and ask for some help if he's got time.im sure all of that stuff would of been checked while tuning ?
if i had other coils to try i would do it right now and im 99% positive there would be no misfire.
tomorrow i'll be taking out the plugs and ill take it to someone to gap them properly for me and see what happens
gap them yourself bruh!
if they're copper, just slot in a feeler gauge and tap the tip with a small meta object..
I'm a lazy prick, so I just bang mine against the radiator support.. works a treat.
  • Like 1
I use the pedestal vice in my shed, but anything will do it, then squeeze a feeler gauge in and see how you go. Basic feeler gauges are cheap, tools are minimal, so no excuses. And learn as you go.....
  • Like 2
dont get me started on YJ's and performance China Racing wise lol. I think a few of you saw the shit storm on some of the products I and a few others had bought which do not fit.
alright alright lol i'll get a feeler gauge tomorrow. i guess its something i do need to learn for myself :P
its extremely easy mate, and a good tool to have. You need to check each plug when buying new, as always 2/6 plugs i have bought have been out by a least .5-1.0
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
    • Me either, I tell people to dig now hence the company car lol
    • It's flawless. (Except for major maintenance bill that non-car people would feel salty about for years afterwards) Just kidding. Life's too short to be bored driving a Camry.
