to me replacing them is more hassle and seems a waste of time if they're going to keep failing
yep... I did that twice, then I it started to misfire again and I was like fuark this... I'm buying Splitfires.. so I did.
Ended up selling my YJ for $100 LOL
The yellow jackets (or even just one of them in your set of 6) are not necessarily "faulty". They're just not necessarily good enough for the duty they're being asked to work in. As replacements for stock coils which have died, on stock engines, most people would not have much cause to question their quality. As replacements (or "upgrades"!) in engines being pushed a lot harder, you will get some people like Ravi who report no problems, some people who report that they just break down and won't make power, and others who report that they they just die. I interpret this to mean that they are not powerful enough in general, and the quality is variable. Seems enough of a reason to pick something else if given the choice.
  • Like 1
^ Well said. Standard engine, standard turbos, standard manifold pressure (12psi max), in my experience they work fine. Once you start leaning on them, I don't think any China coils will handle it.
Works fine for what it costs as a standard replacement. Don't know why people who want to push 20+psi and want to make 300rwkW think $300 coils will be as good as $700+ ones.
Sort of like asking standard turbos to push 15+ psi.
I had (second hand) yellow jackets on 23psi with 0.8mm gap for years without a issue.
Dont know why they dont work for others......
update on the ebay dude:If it is a faulty coil then it would only be 1. It wouldn't be all 6 at the same time.
This alone is an extremely rare occurrence as a lot of care goes into these coils during the manufacturing process.
We will need isolate the single faulty coil though so it can be replaced under warranty.
Thanks.
whats my reply going to be ? should i go for replacements or keep insisting on a refund. to me replacing them is more hassle and seems a waste of time if they're going to keep failing
If it were me, I'd isolate the faulty coil and try to sort out a warranty claim. At least you will get something for free. In the meantime I would plan to get some splitfire coilpacks. Drive it around normally on the yellowjackets, put the splitfires in then get it tuned. I can't remember if it was a daily driver, but mine is so I would do that to keep it mobile so I can at least get places
Sometimes you can test the coils by unplugging them one at a time with the car idling, listen for a noticable change in the engine note/revs, that generally means you've unplugged a good coil (as removing it from the system has made the performance worse)
However, if it only plays up under higher loads then this probably wont work. I did this test with mine and noticed change in engine note on 2 cylinders from memory, but mine played up at idle. Because I was never going to get warranty, and didn't want to risk more failing, I just replaced them all with new splitfires
Buying new coils then having some sitting there doing nothing while also possibly paying for a new tune as it was not the tuners fault. It's all adding up.
I'd be pushing for a refund and explaining the position they have put you in. Might be worth while getting in contact with a fair trade ombudsman.
Also if you paid via paypal contact them with your predicament.
It was paid using PayPal so that sounds promising. I responded to the guy saying u would prefer a, refund and he just replied I can replace the faulty coils. Cheeky prick lol.
I gapped the plugs down to 0.6mm and the misfire improved alot. But it feels like it's lacking a bit down low now. Car only was misfiring under heavy load on 18psi otherwise it was fine. So not sure how I would test the coils. What a pain. I'll have to keep insisting
do a paypal dispute.
Takes way too long figuring out what coil is bad.
I responded again saying I much rather a refund and explained the reasons why and that I had spent alot getting it tuned and will have to again etc.see what he says this time. If he doesn't agree I'll look into the PayPal dispute thinh
While not defending yellowjackets (I run splitfires).
What does the product claim to do? I just did a quick google and found this description from a dealer
Increase in torque.
- No spark blowout at higher boost.
- Improved throttle response and smoothness.
- Increased Ignition Performance.
- Improved Combustion.
- Direct Fit.
- 2 Year Warranty.
- Solid Construction.
- Cost effective.
Unsure if you have a basis for a refund, unless of course you could do a back to back with another brand, but even then, claims such as "no spark blow out at higher boost" leaves it wide open, what is high boost? 12psi? or 24psi?
Anyways, you could persist, or just realise they are known (by doing an hour research) to not work that well, and move on.
Don't forget you have a limited window to initiate a Papal dispute, like 45 days after purchase or something??
As CEF33Y pointed out it's so vague, do these things even have a spec sheet? do Splitfires? Interesting to see if there's a design difference or if it's just quality variability.
also.. I would measure your voltage across RPM for your car..
I had a faulty alternator that would drop to about 12.2 volts at 4~5k rpm.. I have a brand new Circuit Sports one and it holds 14V to Redline :)
However, that's another story.
I'll take it for a drive soon. But as far I know it's above 14k all the time according to the power fc Hand controller. I bought the coil packs November 6th. So that 45 days with PayPal is out the window I guess. Got another reply and he said he will only replace the faulty coils
Edited by deprived777
in regards to repair replace or refund legalities.
https://www.accc.gov.au/consumers/consumer-rights-guarantees/repair-replace-refund
you have a major problem and are entitled to a refund. the refund must come from the retailer who sold you the defective product. and if he gets snarky, you can take them to small claims court for damages and loss, so you can get your money back for the tune.
had a quick read through that.and to me it would fall under a major problem so i think i should be able to get a refund.
he just replied again and said he wont refund them and i mentioned that in his ad they mention no spark blow out at high boost and satisfaction garunteed and throttle response ( which has gone down now after gapping plugs lower)
I told him about accc and strongly insisted on a refund and all he replied was, I can only offer an exchange under warranty. This complied with consumer law in Australia.
So I guess I'm stuck. Maybe I'll just get a new set of 6 and try sell them and buy splitfires. Such a stuff around. Guys a jerk
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
