If you're plumbing your gate back 100% go 3.5" even 4". If you're running a screamer, you can get away with a 3" based on your estimate power goals. Bigger is always better.
Hmm, makes me rethink my plans for a bigger exhaust if screamer makes that much of a difference ;)
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7662447
I'd like an extra inch..
Wait what are we talking about again?
I really do like the sound of those Kakimoto catbacks but i'm not sure 3.5" is going to cut it for ~380-400awkw. Would hardly want to be spending big bucks on one only ot find i need to sell it also.
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7662461
550awkw has been acheived with a 2.8 stroker and 3.5in exhaust (no screamer) - not to say that bigger won't be better
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7662478
I'm currently running a full 3" system with no step downs, however with a screamer... I will be redoing it sometime this year and plumbing everything back and running a 3.5" turbo back, however I'm going to be sneaky and plumb the screamer back after the cat :)
Smells legal when the gate is shut, not so legal when the gate opens haha :)
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7662485
+1 to this, John has it.
Also if plumbing gate back in, make sure you do it as far down as possible, less disruption to gas flow (etc etc)
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7662495
They sound great, restrictive as hell. Been there and done that!
Universal mufflers and get one fabbed up is a better option.
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7662499
With the jap exhuast is it the cannon ore the centre mufflers thats the restriction ? My blitz type r has caused a restriction at 350rwkw i would like to know if its the centre resonator thing or the cannon that restricts flow
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7663467
Look at it?
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7663504
Depends on where they try and hide it.
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=052ac6ac23c0c2b698c6eea679a5d785&app=forums&module=ajax§ion=topics&do=quote&t=462059&p=7663516&md5check=98e788266ec448abb7f617fe94073309&isRte=1,6YgIICLrb3,true,false,NLU5sVbGVpQ');</script>post-27668-1286105372_zps39871ef7.jpg&&0){for(var>
If your rear looks like that, you've found it.
They may have been nice enough to taper it down or after the front muffler too. Such nice blokes.
Holy mother of God. What system is that?
https://www.sau.com.au/forums/topic/462059-3-or-35-exhaust/#findComment-7663552
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
