Hi Guys,
Got some spare bits from my build floating around, need them gone for space for new bits.
Located Brisbane, pickup preferred but should be able to post some stuff. Feel free to make me an offer.
Autobarn88 hardpipe intake kit: $150
modified to have BOV return to both turbos and brackets to suite Z32's but one is cracked (Rb25 ones form superhcheap will replace this easy), Can be used with normal AFM's with the right joiner.
PWR oil cooler: $200
Good condition, never used
Grex oil filter relocation kit: $150
never used, hose has been lost, doesn't come with it.
Stock R32 intercooler: $100
Aftermarket intercooler: $100
exeddy hyper twin clutch pull: $1000
Condition good, used approximatly 20000km/2 years, minimal launches/drag days. Good condition, lots of meat left on friction material, welcome to inspect ask for specific info/pictures.
R32 Rb26 stock pull type clutch: $100
Seems like there's a good amount of meat left on it, flywheel is good. might help someone get out of a pinch.
Tomei ARMS M7655 turbos: $???
Used approximatly 20000kms/2 years. Was making 300awkw's at 20PSI with E85 on a stock engine. Turbos come on their own. No lines, no fittings.
The bad: engine injested about 2L of coolant. Unsure on bearing condition. At the moment havn't got them inspected, make me an offer if you want to take the plunge. Will get them look at in the future otherwise.
Tomei expereme dump pipes: $500
Good condition, standard finish.
R32 rb26 longnose crank: $400
condition as per pictures. Welcome to inspect or ask for specific info/pictures.
https://www.sau.com.au/forums/topic/462063-r32-rb26-parts-turbos-clutch-crank/
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
