Toll Ipec Freight - Wouldnt Use!
hey all
Bought a r32 GTR bonnet from interstate.
Had it sent through Toll Ipec. Do yourself a favour and dont use them!!
Service was good. But when the bonnet was opened found the damage in the pics below.
Despite having 'DO NOT STACK ON TOP OFF" written in huge letters and fragile stickers all over it, and the seller packed really well etc it was heavily damaged. The pics dont do it justice!
They must have put it up against the wall of the truck and used tie downs on it. But tightened it way WAY to much.
Of course no one is taking responsibility for it and now im unsure what to do as itll cost more to fix than its worth IF it can be fixed to being ali....Just a pain as i found it hard to find a gtr bonnet for a good price as is....
Frustrated!!
12404353_10207072789170277_925936117_n_z
12443752_10207072789490285_30824038_o_zp
1914338_10156397758350215_69362325190576
12431782_10207072789010273_1571299399_n_
5564_10156397758450215_61309797979102855
freight companies don't give a shit about your delicate item. "fragile" might as well say "give it your best shot mate". Every freight or postal company is the same.
I have had CO2 laser tubes sent from overseas quite well packed with bubblewrap/foam and with "fragile" all over them and I could tell before I even opened it that the tube was broken. In fact the cardboard box was bent, and the glass tube was basically turned into powder it was so beaten up. I reckon someone played baseball with it back at the depot until they heard the tinkling of broken glass. The second one (packed even better) was broken in transit too. For the third one the vendor had to wrap in bubblewrap and foam and then put it in a solid wooden box before it arrived OK. I told them NOT to put "fragile" on it either. That sticker is just a red flag to a bull.
So, as much as it sucks that they damaged your bonnet, all I can say is the seller didn't pack it well enough. Alloy bonnets are easy to bend, should have built a wooden frame around it. Pack it well enough that it doesn't need "fragile" and you're sorted.
  • Like 1
1) freight companies don't give a shit about your delicate item. "fragile" might as well say "give it your best shot mate". Every freight or postal company is the same.
2) So, as much as it sucks that they damaged your bonnet, all I can say is the seller didn't pack it well enough. Alloy bonnets are easy to bend, should have built a wooden frame around it. Pack it well enough that it doesn't need "fragile" and you're sorted.
Two points! Both true!
1) + 2) = Perfect Storm
+1 for freight companies being the work of the devil
You wouldn't think it difficult to pick up an item from somewhere and transport it to another location, without it getting lost or damaged...but no, they all fail at this test at some point.
JSAI and Bodyformaero have both had good reputations with post and delivery.
How well do they pack their body parts? Any feedback?
What concerns me is, why are you wanting to ship body parts? Are you buying or selling?
We use toll ipec at work for everything...
Utterly useless. Stock arrives tipped over, smashed and sometime doesn't get here at all.
But because we have an account manager, and ship a cubic fkload with them, most claims get approved.
 Share
    • its been that long i forgot about the wrx.
    • Any chance the zero demand ignition table is messed up? Or possibly the minimum tps for it to engage zero demand?
    • 32010-AA520 - R34 RB25DET manual transmission, you can buy this new. You'll need a pull to push type clutch converter (to use R33 clutch kits), or buy pull-type clutch (R34 clutch).   R33 part number if you're lazy: 32010-21U00     Applies: RB25DET.MT.F5; Notes: FS5R30A
    • Hi All, Ive recently pulled my head in and gotten started on my 2year long project for my R32 RB25 swap, I went into it head high and confident it was an easy swap and plug and play wiring. I was wrong. The engine is a S1 RB25 and I'm running RB25 ECU And loom. I got the swap done a few weeks ago and have been working on the car on my time off, however i cannot get the engine to run, at first the engine would crank however the fuel pump would not run,  i dove a little deeper and realised that i would need to connect the wires from the RB25 Body Loom and the RB20 Body loom. went through the ECU pinout and followed the wires from the Body looms one by one to find what was needed to start the car. Now I have rewired the RB25 loom with the old R32 Body loom attached, however i am still having issues starting the car, now the pump works but still wont fire.  The car has spark but looks very weak, however I'm suspect that its not getting any fuel. I have read a few posts related to the "Main plug" near the air intake however cannot find any information on what wiring to hook up to where.  If anyone has done this swap, or has any knowledge at all on RB25's into 32 i would really appreciate your comment regarding this, im really keen to get this car finished.  Thanks in advance
