SHED CLEAN OUT!!! Pics attached!
I sold my Skyline R32 over a year ago and have just cleared out my shed of all the parts I 'planned' to put on it but never did as i'm just too damn lazy. I can post smaller items very cheap but larger ones will be pick-up or buyer can arrange shipping.
For Sale:
* Greddy style Bodykit. Front and Rear bar. Already prepped for painting from shop (some slight scratches from storage)
$800
* R32 GTS-t / GTS4 Carbon Fibre Hood. Seibon TT style. Never fitted only a few very light scuffs from storage which would probably buff off easily.
$800
* Blitz SBC i-color Boost Controller Spec S in silver. Never fitted only opened box.
$750
* Lambo Door Kit. Direct bolt-on kit for R32. Never fitted only opened box. RRP: $1299
$900
* SARD adjustable fuel pressure regulator in silver. Never fitted. Lowest price on ebay $42.50
$40
**AUTOMETER GEAR** ALL ITEMS AS NEW, NEVER FITTED.
* Autometer Ultra-Lite II 5" Shift Light Tachometer #4999. $330
* Autometer Ultra-Lite Pro Comp 2-5/8" Water Temp Gauge #4437. $110
* Autometer Ultra-Lite Pro Comp 2-5/8" Boost Vacuum Gauge #4401. $100.00 (Never fitted but Not in original box as it was thrown away)
* Autometer Ultra-Lite Pro Comp 2-5/8" Oil Pressure Gauge #4427. $130
* Autometer Chrome Mounting Cup for 2-5/8" Gauges #3201. $50.00
* Autometer Chrome Mounting Cup for 2-5/8" Gauges #3203. $50.00 (boost gauge mounting cup)
WHOLE PACKAGE PRICE = $650.00
I work around the country a lot so I may or may not be able to post things straight away. All items located in the Maitland/Newcastle area. Free pick-up or cheap postage on smaller items. Large items pick-up only or buyer arranges postage.
Would u sell the front bar by itself
Yeah I would but I notice you're in Adelaide. I haven't looked into shipping interstate. I'm in Newcastle NSW.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
