Hi guys im new on these forums (upto 2 posts i think) and im a bit of a newbie.
Anyway right now my '86 r31 has a big crack in the exhaust manifold and possibly needs a new head gasket so i was thinking about just doing an engine swap and i've narrowed it down to either an SR20DET or RB20DET.
Can anyone please tell me the ease of droping one of these into the r31, pro's and con's of both engines and some information on the two.
Dori
https://www.sau.com.au/forums/topic/46211-r31-engine-swap-sr20-or-rb20/
Dori
RB20 would be easier to put in, mounting points are all the same, except for the gearbox
Both are about as capable as each other, maybe the RB20 could be taken a little further
As Bluprint said it all bolts in easy,R32 motor and 5speed went straight into my Oz R31 with no welding grinding,it was just like putting a Rb30e in but the RB20det looks more sexy :headspin:
Dori I gather your R31 is oz and if it is the R32 gearbox will bolt up,I'm not sure about imports thou
Plus the Rb20det sounds so much better than the SR20 :aroused:
What R31 is it? Is it a pinny or a skyline?
Pinny's have different gearbox mount locations to skylines. If it is a skyline any rb engine will physically bolt straight in. The wiring is a different story.
I am not sure on the mods needed to make an rb engine fit into a pinny shell, or dropping a sr20 into an R31.
If you have a manual R31 skyline for example and you stick an sr into it, they have a 3.7 diff, and I would assume the sr has less torque then an rb? that would make it a bit of a slug down low.
Also, what do you want the car for? Daily driver? drags? or just to be different? Different would be going sr, a nice daily would have to be an rb30 turbo.
r31 skyline
the sr20 will bolt in you just have to use the cross member from a silvia and extand the bolt holes at the front 1 inch (cost about 20 bux to do) seeing as you have used the sr20 crossmember you usethe sr20 struts and you have a far better choice of coil overs for cheap thus your car will handel better especially with the light weight
now wack in a skyline auto diff (higher ratio so lower top speed but will still get to 200 very quickly)
if your insydey come around and check mine out when its running and make the decision because it will be worrth the compare
and you wont look back from the sr20
pete
what sort of budget are u looking at?
What computer will u run the motor with? (stock ?)
will u do the conversion your self, or will u be paying a workshop to complete it?
Have u also considered selling your car and buying some thing that is already turbo? ( e.g: R31 GTX coupe, GT passage etc?) Doing a conversion may prove more time consuming, exspensive and heart breaking than u may have ever thought?
My 2 cents.......
hey guys thanks for all the replies
sorry its taken me so long to reply but i crashed my car and have been busy tryin to get it back on the road.
just a couple things about the car for those that asked
its an Oz R31 skyline
it will be used for daily driver, drags and maybe a bit of drift further down the track
and lately i've also looked at doing a rb30de conversion
anyway any conversion done i'll be doin myself and maybe a coulpe of friends
i'll be using stock ecu's unless doing the twin cam head swap
any conversion i do i'll be using the r31 5 speed but will replace it later on ( i've just rebuilt it so will try to make the most of it)
not to sure about the budget probably 3-4 grand
umm think i've answered them all
one more thing the only problem i have with doing the rb20 swap is the lack of torque down low. are there any mods i can use to increase power in the low rev range? if i do go the rb20 that is.
anyway thanks for all the help
Cheers
I would sujjest for that sort of budget just turbo the rb30, using VL turbo injectors, ecu, exhaust manifold and turbo. stick a cooler on it and about 10-12 psi and you will have a torquey and powerful R31. Talk to the boys in the R31 skyline club....A lot of them have done it with great results.
that a killer conversion, nismor31jet! rb26 in a r31.....never thought itld happen
i think a few people have them now. I know three coupes do but i think thats the only 4 door (that i know of anyway)
the rb engine is soo cheap now. U can pick up a rb20det with gearbox (out of a r32) for 1650 ready to drop in
yea i already have a rb26dett hr31 skyline
goes quite nice i must say... however just blew the turbos
budget for the sr20 conversion
4door r31 registered to august (very rough car... very rough) 1k
i already had the sr20det so for me free butyou will need a front cut so 3k
do it all yourself
there you go 4k on the road
engineer it 600 bux
4.5 k
im hoping to do it for about 2k on the road but like i said above i already had the engine
should be gravy!
putting the engine in tommorow
pete
if your in padstow come around and help out
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
