On 1/25/2017 at 5:39 AM, Daz said:
Staying local has its benefits
holinger
albins
ppg
It certainly does.
Quaife - Holy Sh*t what a experience !!!
So as above I bit the bullet and ordered all the parts I needed - this was late Jan/early Feb. Couple minor items were on the shelf - but gears, selectors, new input shaft (they said they had a updated better version so I ordered that as well) would need to be made - as its not a production box anymore - I would have to wait for them to do between regular production.
Here we are 10 months later - still nothing!  Been told for last couple months my stuff was ready - but I've seen nothing!  Not sure its if Quaife or there agent we're dealing with in NZ who arranged it all - or a combination of both!
Im just really now starting to want to drive the car again - so its really starting to get to me.........
Once the box is back together (hopefully ;) ) - I will order all new gears 1 - 6 , some selectors, another input shaft and put them away - that way I have a rebuild kit for later / spares on hand.
Eventually one day - Holinger...   but for now I'm sticking to the Quaife (Greddy) - if they ever come through ....
Dan
Edited by IMACUL8
Spelling
  • 2 months later...
For those interested in an OS88, here is the oiling issue that needs to be rectified before you put it in the car.
The little slot where the light is coming through is the breather for the box. There is no cover for it and the gear acts like a paddle wheel and pumps oil up the hole and through the hose. So a cover will be made to stop this.
The oil breather fitting also needs to be drilled and tapped. My fitting popped out once it got in the car. OS must use clag glue to secure the fitting... it doesn't last.
I am also changing the sensor that lives in the bell housing.
so now that I got my os88, can you share how you went about modifying this breather?
  • 4 weeks later...
Just finished an Albins install in a R32 GTR
Lots of work needs to be done in the tunnel, plus remote mounting the oil filter, shifter etc.
It is for a track only car.
The holinger is lighter and an easier fitment but the downside is that they have helical cut gears, no oil pump system and the sequential system doesn't use a barrel for shifting
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
