FOR SALE LIST
Please text 0431143031 with any questions or for further photos
CUSCO 6 point bolt in roll car suit non sunroof S13, only owner in great condition
$750
Microtech LT12S Suit RB
Comes with S1 RB25 engine loom and hand controller
$600
RB PULL TYPE CLUTCH
EXCEDY Heavy Duty pressure plate
5PUK NPC Sprung center clutch used for a handful of track days
$400
Genuine 53mm R32 RB KOYO Radiator, great condition comes with r32 GTR fan shroud
used for a handful of track daysv
$350
Genuine 37mm 28 Row PWR Oil cooler
Comes with lines and sandwich plate
$250
GReddy Style copy intercooler
W 66mm H 300mm L 640mm at top 780mm from inlet to outlet
$200
Surge tank set up
With 2 year old genuine bosch 044 fuel pump (working when removed from car)
$150
Set of 440cc RB26 top feed injectors (Rail not included)
$150
Genuine Tomei fuel pressure regulator
Comes with gauge (no lines)
Used for a handful of track days
$80
Catch Can with lines and filter
$50
MONZA 4 Point Harness
$40
Speed Meter mechanical oil pressure gauge
$20
SAAS Water Temp Gauge
Comes with gauge, neck, sender and hose from an RB25 top rad hose
$40
Edited by aaronfalafel
https://www.sau.com.au/forums/topic/462118-s13rbr32random-parts/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
