For anyone going to a local circuit to knock out some laps, may as well accurately measure the improvement in car's performance and your driving ability by accurately recording lap times.
This particular timer is cheaper ($150-200) then those commonly sold at Revolution Racegear / Speedwerx etc etc. I have another product by AiM and am very happy with it, so whilst this unit is cheaper then other models on the market, i wouldnt be concerned about receiving a cheap, nasty and unreliable unit.
Please read attached .pdf file for all the features.
Price - $400 + delivery
Please, only post GENUINE interest here, the higher the numbers the better chance of a subsequent drop in price.
https://www.sau.com.au/forums/topic/46212-infr-red-lap-timers/
  • 1 month later...
Hey Roy roy, What does the module communicate with? Is there a little device for the side of the track and if so is it included in that price?
good question, would like to know this aswell!!!
I just had a look at their website and thay have
Lap TimerKit Includes:Large DisplayInternal PowerInfrared TransmitterInfrared Receiver So the transmitter will be what is mounted at trackside to send the signal to the receiver which is attached to the timer in the car. Adz will recall the units at trackside at PI in the pits. Just IR transmitters.
these are a top investment if you are serious about improving your lap times...how do you *know* if you went faster unless you can check a timer, often something may feel faster but isnt.
And this is a great price, I paid almost $600 for mine :)
so you get the tranmiiter for trackside and the unit.
this $400 is for the external power or internal?
how much extra is the usb cable and software???
might get 2 if this goes through!
$150-200 cheaper then others on the market. The $400 pric is for internal power supply (do you really want to be wiring up to a 12V feed in the car?).
Anyway it appears interest is low so wont be able to buy in the quantities to get a reduced price...UAS (Boosetd Zed) can get his hands on these cheaper with trade prices and appears is willing to pass on some on the savings to us:)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
