  • Replies 135
LOL...if they are issues, then certainly get them sorted before blasting around the circuit, if its because they are std...thendont worry, std is fine...just get out there and give it a blast.
Any chance of a Fri or Sat night dinner to catch up with SAU-SA folk
just gotta replace tie rod ends, lock hicas, replace rear cradle bushes, get rear camber kit, then it'll be all ready to go :D
im sure we can organise something :( the last cruise we had, the idea of a track day was mentioned and there was a lot of interest. anyone else keen on the track day?
Edited by Sambo33
Is it best to sort accom near the track or in Adelaide, as the soone ri boot accomn around Nth Adelaide the cheaper we get it. I guess its a 2-3 hr drive to the track, may leave mega early Sat morning and go straight to the track, that way Sat night will be cheap as well because two beers and i will be out cold
Edited by Roy
At the minute a token Skyline is driving over from vic to do a Practice day at Mallala.
Its basically an open day at the circuit for ppl to drive their cars.
From their website ...
Cars and bikes Practice Days - start time 10.30 a.m. - gates open at 10 a.m.
- 15 minute sessions are run for each category with 5 sessions per day
- Motorcycles – fast
- Motorcycles – slow
- Closed cars
- Open cars
The day finishes with the final session at 4 p.m. or 4.30 p.m. The cost per day is $70.00 for cars(these charges include GST)
Drivers of cars need a hemet, and clothing (not synthetic) that is full length leg and sleeve coverage.
This is different to Drift Practice Days, and at most tracks its kinda frowned upon going sideways everywhere smoking up your tyres when their are cars around you that are "race cars" looking to do setup work etc.
I have never been to one of the Mallala ones before, but they are a practice day for the full circuit and usually provide a great opportunity to get out and have some fun.
if your all not too scared of a little high speed drift, come down the Adelaide International Raceway on the 11th September opens at 10 (i think)
there using the d-nats layout so you hit the esses's in 4th gear so its pretty quick sliding
they are also opening up the back of the bowl so drifting onto the drag strip will be allowed..
gonna be an awsome day.. im already getting tyres sorted so if your all keen get crackin on tyres as AIR has a tendency to rip tyres to pieces in less than 2 laps
should be fun
Sam.
just gotta replace tie rod ends, lock hicas, replace rear cradle bushes, get rear camber kit, then it'll be all ready to go :(
i'd definitely be keen on a track day! As long as the cars on the road!
I wouldnt mind getting together with some sau-vic boys and having a get together/drink/eat session. keen?
Well at the moment it seems there is only me, and the possibility of the SAU-Vic Trackday cheer leader Bec. When i see them ill be working on the others too... and a session constitutes a good 12 hours on the drink :D
Pass....there is a day at Winton that weekend...plus i think your mad to drift your daily driver, but daily drivers are fine for circuit work...well in my eyes anyway. :D
So Mallala is like Calder where they only open a few corners for drifting?
Edited by Roy
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
