  • Replies 135
Yes Mallala only open the last straight before the small chicane onto the main straight for drift....kinda too small if ya ask me. Pt Gwaler go-kart track was the ultimate drift track...if your into that sort of thing :)
Im still getting my car sorted (steering-tie rod ends,rack rubbers, 4 wheel align., rear camber kit, bigger front brakes...) It needs a quick retune at wot, but will try to see if i can get it out on the track. Would be great to open it up and enjoy the top end properly for once :)
Interesting to see when the forums came back Troy, your user title changed to RB30ET...lol...message in disguise? ;)
Rowdy has had certain problems relating to every panel on his car beign bent, so that a pretty good reason...other then that who knows, ill lay the hard word on him :D
He has 2 x GTR's and 1 x GTST, surely at least one of them is on the road, anyways I'll whinge at him directly as well. :)
come back to adelaide Troy, and ill give u a squirt in my car....so you can tell me what else needs fixing :)
If its running then it doesnt need anything, Nissans are just fancy Datsuns, they may get loud, oily, and scrappoy, perhaps even slower, bu they never NEED fixing as such...well mine doesnt anyway :rolleyes:
have to say that aint true, you slide wherever you want.
you can do the whole track.
how long ago did you last got out?
A while ago now...they had em lined up at the back straight. Then they let em go out, and they did do most of the track, but from spectators pov its pretty sheit, as you cant see 9/10ths of the track...
Pt. Gawler is a much better track imho
There's a drift being organised there for the 29th of next month over on NS.com
No way, Pt Gawler is Shithouse, way too small, think of how fast sliders are taking turn 1 at Mallala.......Pt Gawler is just a controlled burnout over the whole track. It was all good when people first started to get an idea on how to use the handbrake.
    • Well, if it wasn't a GTR I'd say that killing an RB is a perfect opportunity to put in a proper engine. In your case, proximity to Brabus and AMG V12s would be a no brainer for any RWD Skyline engine death event. In my case, because my car is my daily, anything that I do wrong that means I have to do it again is both an absolute pain in the arse (simply having to do it again), and also a doubling of the pain associated with having the car off the road to work on it. I would class a botched head gasket install as not being "engine death causing". More a case of "f**k it's still leaking!"
    • Yeah, this is more stuff like transmission/clutch R&R. Intake manifold R&R. It's not super complicated, but each step matters and you need to be careful and patient. I have heard stories for example of people not figuring out the super coppermix twin plate orientation and getting it wrong on assembly. Removing a cylinder head and putting it back in once it's machined isn't that hard, following torque sequence to install some cams isn't that hard either, but somehow I've seen a lot go wrong between here and there. Scraping off all gasket material isn't that hard either, but I've seen shops ruin heads by using a roloc disk that was too aggressive.
    • There is some shops in Germany that have quite a bit of experience with JDM performance 4-wheelers. I think if it actually comes down to it I'd let one of them do the head gasket. Killing an RB26 is too expensive a risk just to save some money by doing it yourself.
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
