Not sure on a 34 but when I first did the conversion I got 33 GTST injectors (think they are 370cc too), Walbro pump and a GTST ecu, ran 12-14psi off a bleed valve and it was fine.
I don't see it as a great investment to put all the work in and miss a few pieces of equipment which limits your boost. I had the same thoughts as you about keeping the car. I like the car, it's clean and well looked after, mine is a GTS4 so I liked the AWD aspect etc so I decided to put the money into it.
Provided your car has been looked after and the engine isn't tired you will be able to run more boost then what you are after with the right mods.
Here's a killer difference though. You're unlikely to destroy the GTS4's gearbox with a 25DE+T at that boost level - it's tough enough. The skinny box in the RWD NA cars though is going to be twisted out of shape and not last very long.
What others have said about brakes and all that is still true too.
Okay after a lot of thought and reading through all the replys im thinking of giving the car a tidy up and try and sell it, then buy an r33 gtst with the money hopefully.
Thank you to everyone who opened my eyes on this, glad i didnt just go ahead otherwise i would have most definitely destroyed my engine.
  • Like 3
Financially smart. Could have been done mechanically though! I'm running 16psi through an NA RB motor, without issue. But the compression ratio is slightly lower.
Howd you manage that? And why didnt you sell the na and just put a det in instead?
Well, it's not impossible. The only limitation is boost vs fuel octane (until you start reaching the mechanical strength limits of things, like rods or valve springs - and even then you can replace stuff until you reach the limits of blocks!).
Because they are all but exactly the same short motor apart from piston dome volume and some very minor cam timing differences and oil squirters
My setup is on a different NA RB motor, but still a similar premise. NA+T will work fine, ideally you want it tuned and especially in my case where it's running 16psi. But 5psi through a NEO with an FPR to increase the fuel pressure should be fine, the nature of the factory ECU will compensate the extra air with extra fuel, obviously to a point though. He should definitely run it on a dyno after installing everything to make sure all is well.
I had a N/A once, then put a DET in and that was only the beginning.
There's just way more little things between the NA and the DET that may or may not rear their ugly head or annoy you, things you thought were the same... just aren't. A bit of bracing here, slightly stronger doohickeys in the chassis, just... things
The best and only mod for a GT is a GTT. It is the best bang for buck, and it is ultimately what anyone with a GT wants.
  • Like 1
Is true about the gearbox... and yes changing brakes and stud pattern over was costly and annoying so no arguments there :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
