Angle grinder or tin snips.
Take as much/close as you can basically. I used an angle grinder, because power tools. :D
Oh awesome I have two, one for each hand! Ooo that'll be a fun project...
Yuh, I think it is something that falls into the category of "modifying a braking or steering system" (to paraphrase their various publications) on which the rules are pretty much "don't touch anything unless you get it engineered"....and they apply that rule in blanket fashion as it is easier than thinking. Rock shields might not do much......but they are there and they were put there by the factory, so there they must say unless someone smarter than all of us says they can come off.
I think thats probably the most logical answer.
Rules to cover arses......if unsure disallow it.....and call it a mod that needs engineering.
  • 1 month later...
Edit, what colors are the 3 temperature markers going from left to right?
If they are White Yellow White, you cooked that baby good, well over 650 degrees, id say the inner part of the rotor went over 900 degrees and glowed a nice cherry red color, hence the burned off paint. :D
Here's what the front rotors look like after about 13,000 street kms and 3 track days - I reckon they've been pretty hot:
I'm yet to cut off the rear shields.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
