Nismo Cluster in good condition and working order.
has the usual crack in the speedo cable connector, but does not effect operation.
done 67779km.
$580
Nismo Horn button in good condition
$150
Nismo Cigarette light, its brand New never used.
$230
BNR32 Vspec genuine BBS wheels with tyres. 17 x 8 +30
Wheels have been professional repaired and repainted to the original specs
they're in perfect condition.
Tyres are yokohama 225/50/17 DB decibel with 4mm and 5mm treads.
$1300
Located at mortdale and happy to ship at buyers expense.
0449 292 986
thank you.
  • 8 months later...
Hi Roy,
I'm wondering if the Nismo Horn Button is still F/S?
I'd like to know if it fits my wheel too before buying?
Regards, Terry
  • 1 month later...
11 minutes ago, elinaki31 said:
They are on my car. Keep a lookout on ebay they do pop up.
Haha no worries, thanks for letting me know buddy :)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
