Hi Im new to these forums, and as the R31 Skyline Club site is down for the time being (changing server it would seem) I was hoping some people on here will help me with some issues im currently having with regards to an upcoming regular servce.
1. Basically its ran up 193,000 kms on the clock and im getting woried about the timing belt. Had a look at it the other day and u can see light brown marks on the non-notch side of it, does this indicate wear?
2. Plugs. It needs em bad. NGK seems to be the general consensess, but what about the irdium ones....worth the extra money? (how much "extra" by the way havent been to autobarn yet)
3. The motor (RB30e stock running 20 degrees) is running like, well, not good under roughly 2 grand but then at 2000 grand u feel it really thump and it takes off (mainly first gear and second (manual), never do 2000rpm in third) its feels like its almost fuel related....filter maybe? Dont want to randomly replace parts i dont have to (uni student). Again it has never done this until a few days ago...also i know my air regulator is stuffed so would that cause that kind of problem?
If i even get one of these questions answered that would be bloody fantastic
Thanks in advance Luke.
https://www.sau.com.au/forums/topic/46221-techicnal-rb30e-running-issues/
yea our r31 is around the 200,000km mark.
Belts -
The timing belt should be changed every 100,000kms but it will most likely last past 100,000 for a while depending on when you replaced the older one, but its best to replace it.
Im getting all the belts on mine changed, the power steering one is starting to fray and i think the timing belt isnt much better.
plugs - I would just buy the copper ones, they do just as good and they cost alot less but i think you get more kms out of the iridiums.
It would be a good idea to change the petrol filter. Its probably blocked up with shit, it will make a fair difference after you change from a bad filter to a new one.
Other things while your at it -
Perhaps change the air filter and clean the throttle body.
An oil + filter change if it needs one - some good quality mineral oil would be fine and its not to expensive.
Thats most of the stuff thats been done on my r31, but i still need to change all the radiator and heater hoses as they are getting crunchy and the radiator needs flushing. Plus i think the thermostat has stuck closed as the temp needle gets to high very often.
You might wanna check your air flow meter if you are having problems under 2000 rpm. Just a thought. This is what you might mean by air regulator. AFM's are not all that cheap, but can cause a heap of agro if they are on the blink. I agree with SKY-031, 20 degress is a bit on the high side if you are running standard unleaded. If you want to run PULP, 20 degrees is OK.
yeah ive been meaning to check the timing again for a while now, and after hearing it pinging 2day pulling up a steep hill, second and low rpms, so i took it home and checked it. To my suprise the timing was not at 20, but more like 13-14 degrees :) doh what else causes pinging? Or makes a softish *clink* *clink* *clink* sound under those driving conditions? Wasnt hot 2day either 10-12 degrees ambient temp...
Cazz....yeah I have already done extensive testing on the AFM, when i say air regulator i actaully mean air regulator :) its stuffed (sorry should have said that it was ok ::). Thanks for ur help anyway always appreciated :).
Thanks everyone for advice/help will 'report' back from service 2moro....hopefully my mechanic mate can shed more light on my issues
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
