Hey lads,
Recently bought an R34 GTT. This morning I hit the TCS off switch to see how that goes. Now the TCS off, SLIP, and ABS lights all came on and are staying on. Can't for the life of me figure out turning the TCS back on. Before I hit the switch none of the lights had come on previously.
Thoughts? Apologies if this is a repeated thread.
Cheers
BG
https://www.sau.com.au/forums/topic/462218-tcs-slip-and-abs/
Yeah there are heaps of threads covering this. Use Google.
Easiest way to find the issue is with a scan tool. Generally means there is something wrong with the ABS or brakes or similar. Could be simple, could be expensive.
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
