Generally about $200 for a Sandown day, maybe $230 for a PI?
We often don't actually run all of the rounds in our championship, some of the rounds we join other clubs on their days.
Is there a website for sandown just for general practice days. Sorry for the dumb question with mallala down here they have general practice days go there pay ya $110 entry and go play around does sandown do days like that?
Hi All - a nice mid winter cruise - weather dependent - sounds enticing to me. Any interest from others? I'm not fussy about a route as long as it's out of town - the cruise up to Kinglake and back is not bad and doesn't take all day either.
  • 5 weeks later...
Hello,
I'm a new member and would like to know what the requirements are to attend a track day, such as Winton?
In the past I have needed a helmet, is this still the case and are there any other requirements?
I actually just saw the thread track day requirements. Apologies
  • Like 1
Im interested in doing the motorkhana day in Nov, regs says cars need to be roadworthy. I assume that doesn't exclude dedicated track cars? engine swap, no door cards etc. ok for this event?
See if you can view supp regs for a previous event.
Scrutinteering basically checks helmet & seat for Australian standards sticker, checking fire extinguisher is within date, checking seat belts/harness, and making sure nothing is going to fly around inside the car or is not properly fastened in the engine bay.
"Roadworthy condition" is sort of like a blanket statement for saying the car meets basic safety requirements.
But yeah, unregistered cars are allowed.
champion, thanks.
Did not see a GOR run mentioned anytime during 2016 , was there one late 2015 or is that run off the agenda for some reason?  I am not rejoining so would that be a problem anyway as I remember we used to do Members only and Open runs also.
  • Like 1
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
