R32 Gts-4 Wheel Studs
Easy place to start is jack up the front end, turn steering wheel lock to lock and see if any air bubbles purge. If nothing happens it's probably time to pull the pump and inspect. It could also be a line is clogged for whatever reason and you need to isolate the part of the system that is blocked on the high pressure side causing the pump to be unhappy. -
qld plates “GTR R34” for sale $5500 (listed else where)
Or, just take PS pump off and inspect? Does no-one do this any more?
By drifter17a · Posted
Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes i will raise the front of the car and will turn side to side to test id bubble goes away
