Hi all
As stated, anyone know about this 260rs on carsales?
I emailed the seller via the carsales network and get different stories about the car when i emailed the same seller when he/she advertised this car on Gumtree.
At first, it's got a fully built engine to Nur Spec, then it's got an R34 gtr engine, then it's got a standard R33 gtr engine ......... wtf. When i confront he/she in the last email with all the different info that he/she gave me via difference networks, i never got an answer.
http://www.carsales.com.au/private/details/Nissan-Stagea-1999/SSE-AD-3563022/?Cr=3
At the same time, if anyone here thinking of letting go of their 260rs, please inbox me.
Thanks
Interior trim around the A/C controls, key barrel and passenger front door looks terrible.
Passenger door has either been replaced or resprayed (Most evident in the first photo).
"exterior is in showroom condition and the interior is practically brand new" hahaha, yeah right.
Advertised as 1999 but described as 2000
"Car is 100% stock standard with no modifications from factory". Those aren't factory seats, grille, N1 style bumper vents or wheels.
I thought all 260's had the momo steering wheel ?
That car just doesn't look right at all.
Edited by Jezboosted
  • Like 1
Thank alot for the feedbacks!
  • Like 1
series 1 has normal nissan steering wheel
series 2 has momo
thats what i seen so far which is why this car doesnt matchup with a series 2 front and a non momowheel
  • Like 1
Passenger door could have had the rust fixed. All Stags rust under the mirror. Owner might have cared enough to fix it which is possibly a good sign.
I got my car with 130,000ks on it and the steering wheel had a hole in it. My brand new Nissan Pulsar has 30,000ks and the steering wheel is already very worn in the same area. Nissans seem to have an issue with their steering wheels (never had the issue in other cars).
There are potentially valid reasons for most of what you have pointed out. Also most people use "stock" to explain mechanical condition, not body kits.
I'm sorry but when someone advertises a car saying "Exterior is in showroom condition and the interior is practically brand new" you don't expect to see mismatched paint and chunks taken out of interior trims.
  • 1 month later...
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
