hey i just got my R32 gts-4 lowered but im not sure if its low enough the guy that did said i could go lower but im not sure i was wondering what you guys think?? im also looking for some rims but im not ure if 17" rims look alright or should i go 18"?? prefer 17" due to price but if they look shit i dont mind spending a little more?? attached are some pics if you could tell me what u think
https://www.sau.com.au/forums/topic/46227-how-low-should-i-go/
who lowered it? how low did you go?
i lowered my car 2 1/4" and it was still high as fu(k in my eyes
get a set of height adjustable coilovers and go 3 inches.
i think 17s look sh!t go 18s or bigger if your budget allows it.
the price of 18" rims has droppped heaps the expensive part is tyres.
100mm is the legal ground clearance my car was 65mm from the ground and i didnt have much problems with getting around apart from my rear muffler, but the thing was huge. if you maintain the 100mm clearance you shouldnt have any problems
my 2c
2GU UP 2
No problems scraping even at 65 mm? That's really strange. Because I have an r33 with the AERO STYLE CHIN SPOILER from UAS. I have coilovers, and even when i set them at stock height, it scrapes to the shithouse. I guess it is a bit different to your car though. The lip sticks out a fair bit. That must be the diff. Because on r32s, the front bar sticks in a lot.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
