have my mid mount gtx3071 .82 of my r32 for sale.
turbo/wastegate/bov/fabwork/lines are all no more than 3months old with MAX 3000kms, I fitted the turbo drove to queensland did matsuri and drove it home, I then broke my leg not long after and car has sat in garage since.
I want to sell it all together at the moment but will eventually break it up if no one is interested, this is perfect for someone wanted to save some cash and avoid police issues by keeping stock manifold and out of sight mid mounted. will fit 32/33 will fit r34 but not sure if it will match up to stock air box location? will also fit ceffy and rb20/25 powered car basically
contains:
gtx 3071 (new type with the upgraded bearing cartridge) . 82 coated housing with 40mm turbosmart welded to housing with stainless screamer pipe.
40mm turbosmart with upgraded 14psi spring
custom intake pipe suit afm and airbox with bov return
30mm stealth turbosmart plumb back bov
standard manifold with longer studs/nuts and spacer to suit
heat sheild
2x genuine Nissan turbo gaskets
speedflow oil feed line and fittings
speedflow coolant lines with fittings
custom oil return with quality oil specific silicon hose joiner
cross over pipe with bov to suit intake pipe
3 inch v band dump to suit r32/r33 with v band clamp
hks elbow to suit plumbing
basically all you need to fit up to your car and away you go (bar one coolant line that im keeping)
made 275kw on 21psi pump 98 on my rb25. with dodgy boost controller.
builds boost from 2k and comes on song 3800rpm has more in it with proper boost controller.
drives really nice motor loves the housing revs very free now.
I also have a greddy return flow cooler kit that fits this all, can do a combo deal if someone wanted everything.
this is a legit no expense spared kit I never planned to sell but as usual a bigger turbo setup came up for sale that I couldn't pass on.
i am in Hornsby for pickup or can send aswell, if you want more/better pictures msg me and ill be happy to send through
chasing $2800 for everything, can take parts out for cheaper, either way if someone wanted to do this setup half the works already done
0419469108
cheers harry
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
