Matthew Squarepants Posted January 16, 2016 Share Posted January 16, 2016 Hey guys, I have a R34 OP6 turbo which has been high flowed by GCG from previous owner. Car is blowing light blue/white smoke and I suspect the turbo seals are out. Car still boosts fine, checked shaft play of the turbo and it's fine, compression tested the engine and it was fine, checked intercooler piping and there was a bit of oil in there. So I was wondering am I able to buy the standard op6 turbo seals and change them? If so where can I get them from as I can't find any? Any help will be appreciated thanks. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/ Share on other sites More sharing options...
hypergear Posted January 16, 2016 Share Posted January 16, 2016 The seals are just stainless steel Clips. they don't ware unless there is an abnormal amount of shaft movements. That is also indicating the bearings needs replacing. If it is one of their Xtreme BB using OEM bearing housing then only they can have it repaired, or it might be cheaper to re-highflow. Alternatively if it is a T3x bush bearing center, depending on how bad the shaft and wheels are, you can simply replace the bearings and seals, we can supply the bearing kit at if required PM for details. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668304 Share on other sites More sharing options...
75coupe Posted January 16, 2016 Share Posted January 16, 2016 Its probably something else making the smoke Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668313 Share on other sites More sharing options...
Matthew Squarepants Posted January 16, 2016 Author Share Posted January 16, 2016 Yea it is one of their ball bearing high flows. Thought the turbo would still be fine if it's still boosting hard. Anything thing else I'm missing that could cause this smoke? Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668320 Share on other sites More sharing options...
Ben C34 Posted January 16, 2016 Share Posted January 16, 2016 Heaps. Blowby. Gumby breather routing. Head gasket. Oil in intercooler and pipework. Rings. Valve stem seals. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668322 Share on other sites More sharing options...
Matthew Squarepants Posted January 16, 2016 Author Share Posted January 16, 2016 Well then it's either the turbo or vavle stem seals. Any way to test the valve stem seals before I go rebuilding the turbo? Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668339 Share on other sites More sharing options...
Ben C34 Posted January 16, 2016 Share Posted January 16, 2016 Well then it's either the turbo or vavle stem seals. Any way to test the valve stem seals before I go rebuilding the turbo?Why are you so sure it's nothing else causing it? Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668383 Share on other sites More sharing options...
Ryno Posted January 16, 2016 Share Posted January 16, 2016 I had a similar issue years ago. Blowing blue smoke, especially after a period off the throttle (under deceleration). Because the engine compression tested fine, I assumed it was the turbo and got it rebuilt. It didn't fix the problem. After I got the engine pulled apart it turned out to be 3 cracked pistons. [emoji20] Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668429 Share on other sites More sharing options...
75coupe Posted January 16, 2016 Share Posted January 16, 2016 When does the smoke appear, on idle, when warm, decel??? More info? Why do you think its either turbo or valve stem? Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668450 Share on other sites More sharing options...
Matthew Squarepants Posted January 16, 2016 Author Share Posted January 16, 2016 I have taken the intercooler and piping out and it had lots of oil in it. Gave it a clean, fitted an oil catch can to the car venting to atmo so no more oily fumes can get in there. Compression test showed up fine (160-165psi) so I thought I could rule out the head gasket. The engine has had a rebuild from previous owners. Not exactly sure what was done as I've lost the receipts 1st week of owning the car lol and knew nothing at the time about cars when reading the receipts, but surely a rb25 with over 200 000 km's with compression like that should be a good sign? The car has been smoking for some time and use to only smoke on idle sometimes and a lot on boost. But now it just constantly smokes. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668561 Share on other sites More sharing options...
Matthew Squarepants Posted January 16, 2016 Author Share Posted January 16, 2016 I've also just pulled the intercooler piping out a week after installing the catch can, to see if there would be any oil in there, but it's all clean. I've also notice some smoke or vapour is coming out of the breather on the catch can. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668565 Share on other sites More sharing options...
Ben C34 Posted January 16, 2016 Share Posted January 16, 2016 If it filled the pipework by breathing heavily the engine is suss in my eyes. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668568 Share on other sites More sharing options...
75coupe Posted January 17, 2016 Share Posted January 17, 2016 Is smoke actually coming out of the exhaust? Could be anything, the fact that you thought installing a catch can with just a filter on it not plumbed back just because there was some oil in the pipe, who knows how long its been building up, says that maybe your ability to diagnose is even with you being able to give a description of what the is it happening, when, and under what conditions. Would love to help but your not making this easy or fun Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7668806 Share on other sites More sharing options...
hypergear Posted January 18, 2016 Share Posted January 18, 2016 Easiest way to check a turbo is to have a feel of turbo shaft, there should be under a mm side wise and nothing in and out. Link to comment https://www.sau.com.au/forums/topic/462296-changing-r34-op6-turbo-seals/#findComment-7669047 Share on other sites More sharing options...
