I've been looking at some upgrades for my GT,
From what i can see there is some differences between mine and the GTT model.
Coilovers - mine are eye type rather than fork type in the GTT, have been reading coilovers for an R33 GTST Are the ones to get for my car is this correct?
Adjustable arms - are any of the other suspension arms and components different in mine compared to the GTT, For example adjustable camber arms I've been looking at.
Diff - I've also been looking at specifically a Kaaz 2 way diff, is the the diff housing the same and i can just purchase a 2 way for a GTT for my car?
Driveshafts/brakes - are these also the same between the two model's? maybe the best thing is to grab a complete rear subframe with brakes and all arms from a GTT and put it in my car and then use the proper r34 coilovers.
Any help is greatly appreciated
https://www.sau.com.au/forums/topic/462324-r34-gt-questions/
All of this information is already available on these forums. By searching.
But for nom nom spec spoonfeeding value.....
Coilovers. Yes.
Arms. All the same.
Diff. All R200 housings will swallow all R200 centres, with only a few confusing exceptions that you won't have to worry about.
Driveshafts. No. You have 6 bolt (3x2) axles, the same all all the shittier Skylines and Silvias. Turbo Skylines have 5 bolt flanges and tougher CVs. GTRs have beefy 6 bolt flanges and are tougher again.
Brakes. No. NAs have shitty sliding caliper brakes. GTTs have opposed pistons. You wouldn't put the rear brakes from a turbo on a car that has NA brakes at the front. But you can fairly freely swap all of them. Note that R34s have bigger caliper bolts than all earlier Skylines, which will make it harder to mix/match outside of the 34 breed.
  • Like 2
Coilovers. Yes.
Arms. All the same.
Oh i have been searching, but as i'm sure your well aware there is a million different posts on a hundred forums all with conflicting answers so its nice to get a knowledgeable answer to a specific question, :happy:
Plan is to swap over as much as the good stuff as i can, that would include the full brake setup. Best bet seems to be to find everything from the back end of the GTT in one go and get it all in there. Since i do plan on an eventual engine swap id like to make sure everything else is prepared first and doesn't start to fall apart with the extra power.
Edited by JDMfrank
Buy gtt. Job done.
If that was an option i wouldnt be asking these question's. :no:
Would i be correct in saying if i grab myself, hub's, break setup, driveshafts and rear diff from the gtt i can go ahead and bolt these into my subframe without issue?
Where the propshaft bolt's too the diff is the same or different again?
Also, there are possibly a couple of traps for you here. I know that GTT diffs have 2 code rings for the ABS/traction control. One on each output shaft. What I do not know is whether the NA diffs have these, of if they have a single rear sped sensor off the side of the housing like some of the earlier/shittier offerings from Nissan. Or if they have none. I'm guessing none is not really an option as most of these cars should at least have had ABS.
The reason that this is important is that you can't change the sensor arrangement for the ABS/TCS computer. It will have a panic attack.
Please take some photos of the rear end of your car (from underneath) if you want any advice on which of a couple of options is the best for you to go forward with.
Tailshaft same.
As I said above, and just in case you were still considering it.....do not put rear turbo brakes on unless you do the fronts too.
Frank. What country are you in?
No the plan is to swap everything over, i wouldnt be putting on the rears without the front's. Ill grab a couple pictures of underneath for you tomorrow.
Im in ireland. Appreciate the help.
Edited by JDMfrank
Good stuff. Get as much detail on the diff housing as possible. In particular where the driveshafts connect to the flanges on the sides (where 2x speed sensors would be), the right hand side of the housing (where a single speed sensor would be), whether or not it has a rear anti-roll bar, and any other detail you can capture.
The other trap that just occurred to me is that your NA rear subframe probably doesn't have HICAS. The GTT subframe will. HICAS is gayer than a Liberace performance, so you definitely do not want that. It may in fact be smarter to retain your NA subframe. On my R32 I went to the trouble of getting a non-HICAS subframe so I could do a total HICAS delete.
Ok until i can get it onto a lift I've got some questionable shots of underneath.
What i can see:
- No hicas.
- No arb.
- single speed sensor on right hand side is where it should be.
- 6 bolt shafts as you said.
Best i can do for now are these:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
