Well it’s a sad day for me but a golden opportunity for someone looking for a tough RB. I have bought another shed ornament so I’m parting out my R32.4
Fully built RB26
CP Pistons 40 thou over size
Eagle rods
8.9:1 compression
ACL Race bearings
ARP head studs
Custom sump approximately 7-8 litres with Tomei oil baffle
Moroso external oil pump
ATI harmonic balancer
Grout filled block up to the welsh plugs
Ported head. Large exhaust and a bit smaller on the inlet to keep response
1mm oversize Brian Crower valves
Supertech double springs 90 pound
Bronze valve guides
CNC multi-angle valve seats
Cams inlet 264⁰-10mm lift and exhaust 272⁰-10 lift
Adjustable cam gears. 10⁰ on the inlet gave 500rpm extra response
Non genuine Mines style cam cover baffles
Dash 12 fitting on cam covers
Cam covers, coil pack covers and plenum all painter 2 pack metallic blue
880 cc injectors
New coil pack wiring loom from Wiring Specialities.
Only ever run E85
Produced 550 rwhp but mechanically built for 800+ rwhp all day
Changed oil every 3 events maximum and it was always clean when changed. Always ran about 85⁰c.
Can have engine running and able to do compression test but the car can’t be driven
$7k ono. I’m motivated to sell but will ignore idiots!
RB25 6 Boost manifold and Garrett GT35R GCG core steel bearing cage instead of the plastic standard cage turbo with braded lines. $2k
RB26 Apexi Power FC with hand controller, two air flow meters, y pipe, 2 big pod filters and all the silicon joiners. Wiring loom to suit r32 with mil spec round connector at the firewall. $800 ono.
Or take the engine, hot side and ECU for the a drop in package that puts you in the 500+hp club for $9k!! Tuned by Brad from Turning Point Technology.
Not on SAU very much so call or text 0414 236 724
HP and Torque - Turning Point Technology.pdf
https://www.sau.com.au/forums/topic/462346-forged-rb26-500-rwhp/
Where was this engine 4 years ago after my indiscretion?
Good luck with the sale.
Sounds like a monster engine.
Cheers
Edited by Bart Japan
  • 4 weeks later...
  • 2 months later...
