Hey all
Recently my brother has bought a R31 station wagon.
Started its life as a non turbo, but has been converted on the same non turbo block to a turbo.
does it have to go through regency now?
Can i just tell motor reg its now a turbo?
Will the insurance company be ok with it being a turbo?
cheers
https://www.sau.com.au/forums/topic/462387-legality/
I was surprised about a year ago when I found that SA Transport webpage does now list guidelines on modifications, and what is and isn't illegal. For this particular change - adding a turbocharger:
https://www.sa.gov.au/topics/transport-travel-and-motoring/motoring/vehicles-and-registration/vehicle-standards-and-modifications/aftermarket-components
Turbo-charging/supercharging petrol engine vehicles
Turbo-charging or supercharging an engine increases the power of the engine and may increase the exhaust emissions, fuel consumption and reduce the service life of the engine.
Passenger cars and passenger car derivatives (car type utilities and panel vans) manufactured prior to 1 July 1976 and fitted with petrol engines can be fitted with a turbocharger or supercharger to the original manufacturer's engine without DPTI approval.
For cars manufactured on or after 1 July 1976 the fitting of a turbocharger or supercharger requires one of the following:
  • the vehicle is fitted with a Second Manufacturer's plate to demonstrate compliance with all Australian Design Rules
  • the vehicle to pass an IM240 emissions test
  • the converted vehicle is identical to the production turbo/supercharged vehicle.
In all cases a statement of requirements is required and the vehicle must pass a roadworthiness inspection.
Certification from a professional engineer may also be required. See list of qualified engineers recognised by DPTI - MR426 Chartered Professional Engineers 409.4 KB .
I'd imagine these sorts of engineering changes would include checking over whether the brakes are adequate, any changes to the fueling system are within specifications, that adequate exhaust & emissions systems are in-place, etc.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7670660
I thought the general consensus with these cars was to keep N/A's that way, as they're then still P-plate legal, and those are in-demand. Also - the cost, engineering, legalities, and extra police attention of a converted car (and they're probably worth less than a factory turbo, or plain N/A) making it generally better to just buy the turbo car instead.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7677510
Yes, i thought so too. But people still want to do it for some reason..
I guess for them its not about the money or the legalities its about the project, and they can then complain about the whole process and unwanted attention.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7677574
Only makes sense if u have a wreck that u got for fu*k all with all the required parts to raid. Still lots of work though. I still wouldn't do but each to their own.
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7677602
Ya I understand what you guys are saying iv had my car for 6 years since on my L's and know that I can drive a turbo I was going to turbo it it more because I have spent a lot of money on it makeing it look they why I want it to look and have growin a attach meant to it and don't think I could sell it I pretty much have all the stock parts to turbo it so know it almost time to take it to the machines to get down
https://www.sau.com.au/forums/topic/462387-legality/#findComment-7678018
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
