As pictured (though that's not mine) has anyone tried removing the existing foam and replacing it?
I'm interested in how you went about removing and cleaning up the old foam/adhesive from the double sided tape they appear to use.
Edited by ActionDan
Started last night, turps helps a little (in conjunction with gasket remover).
I looked at the goof off stuff, appears to be mainly acetone so I'll try a little nail polish remover on a small section and see if it helps.
Edited by ActionDan
I replaced my foam awhile ago, Bunnings sell self adhesive backed foam rolls like this stuff http://www.bunnings.com.au/weatherseal-handy-mws5-19x25mm-3m-garage-1-28105_p4114647also good for sealing air box snorkel with the airbox
I have exactly the same weather seal on my airbox. The only issue is that because of the shape it tends to come off at the notchy bit sometimes. Doesn't matter normally but not ideal when it gets sucked into the snorkel at the track...
