Hey guys, after wanting a skyline since I was 15, I have finally managed to get one after waiting many many years to get off my P's. Been a Honda guy for a while, owning a couple of b swapped civics but it was finally time to get a turbo rear wheel drive.
Picked up a silver 96 R33 GTST, with a couple of mods;
- front mount
- 3 inch turbo back
- hicas delete
- boost gauge
- Shock and Spring combo
- TE37 reps w/nismo stickers which I'm gonna piss off
Plans are to up the boost to 10 psi, pod filter with shield, remove spoiler, and install my nardi and bucket seat from my civic. Also going to get a decent alarm installed and fix/install the central locking.
Keen on cruises and meets & greets, and will sign up to SauVic. Hope to see some of you around
  • Like 1
https://www.sau.com.au/forums/topic/462411-first-skyline-owner-melbourne/
Welcome and congrats on your new purchase. There are some cruises coming up. Search for old school cruise. I think there's 1 on the 28th Jan. There is also a track day at sandown on the 30th, will be a good day to meet other members and check out what goes on.
  • Like 1
Hey guys, so I've installed my turbo smart boost tee and adjusted it to run 10 psi. It runs fine, but a part of me reckons I did the lines wrong. Here are some pics, can anyone tell me if I did it right or wrong??
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
