Labour To Replace Rear Knuckle Bushes
I honestly don't know what an SPL solid is so I'll guess its a type of bush, and I assume rear knuckle is the rear hub/upright assembly.
There are a billion bushes at either end of the control arms, and yes if they've never been changed they are likely to be rooted. 6 per side + possibly 2 more depending on your hicas/nocas setup.
The best bet for a road car is generally an adjustable poly bush like whiteline or superpro because they are quieter, last much longer but also allow some extra adjustment for alignment particularly useful if you have lowered the car. Rose joints / rod ends / spherical bearings /whatever you want to call them are generally a bad choice for a road car because they wear quickly and make nasty knocking noises, think under 20,000klm.
And finally, it is a prick of a job to get all the bushes out and in, get a workshop to do it unless you have a big press and fittings, or unless you really enjoy frustrating and hard car jobs.
Pressing bushes out of large cast pieces can be hit and miss. Sometimes the shell just wont let go, and youll just end up bending things if you go stick it on a 20 ton press.
The easiest way to remove the rear ones is to heat the inner tube to separate it from the rubber, pull it out using a bearing puller (or even some threaded rod and creative use of spare metal tubes and sockets), then use a reciprocating saw to SLOWLY cut through the inner shell until youre able to knock it out with a hammer and punch.
You'll need a lot of patience, but if you use the right tools, it makes the job far more pleasant.
Then just stick aftermarket arms on there, because no one wants to do twice the amount of bushes.
well....if you get the right support on the arm and it starts to press out easily, it's MUCH quicker than doing the 3-stage cutting method, but sometimes that way is needed, certainly was in my case, but I did it with the knuckle on the car, and it was a PITA. PUll it off, give it a complete overhaul in one step.
+100 for everything above, steel sleeved OEM bushes are a massive pain. I've done the rear camber and traction arm bushes (off the car without a press), the HICAS ones and the diff bushes (on the car yay) and they all take ages and are extremely tedious.
I reckon you'll end up paying 2-4 times the cost of the bushes in labour. And it's still so worth it.
If you're like me and you are OCD about knowing what it done to the car, it can be worth doing yourself. For example I remember that I needed to modify the 4 bushes (8 split bushes) that go in the A-arm at the rear with the ball joint. They were superpro ones, and the 2 halves were a little long, so they poked out of the A-arm shell too much, and were extremely tight in the subframe. Not only would I expect the bushings to eat themselves, they'd probably squeak like crazy after a while. If there's a mechanic you can trust to spend that much attention to detail, then it may be worth the labour.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
