hey guys,
sorry if this in the wrong section please move if so.
But i was wondering if i could turbo my NA R33 ? I was thinking of buying an RB25det taking the turbo manifold off and bolting it onto mine or just do a full engine swap. i'm on my red Ps' in QLD and wanted to ask this question befoer going out and paying for a exemption application.
thanks
https://www.sau.com.au/forums/topic/462413-na-to-turbo-a-p-plater-question/
Sell car and buy turbo version. Cheaper, smarter, better but if you really want to turbo your na you can or put an ls1 in it. I'm sure others will come along to give u some good advice.
thanks for the quick reply, i don't really wanna sell my first car that i bought but i wouldn't mind a turbo either, my friends told me buying an RB25det second hand and using the motor as a spare isn't a bad idea but neither is spending a lot of money.
Svn,
Honestly, these threads get created often and the answer to the question is to just sell your NA and buy a GTST.
You will save loads of time and money, they can be had for very cheap these days.
Lots of the time the people asking the question still think its a good idea just to pull the engine out and put a RB25DET in it.
But then you have to think about other parts on your car which do not suit the turbo or are not up to spec eg. Brakes.
Just learn to drive right now, there is a reason why you aren't allowed to drive a turbo car.
Once you get off your P plates, go spend the money on a nice GTST, GTR or GTT
  • Like 1
Svn,
thanks for the breakdown mate, looks like i gotta start saving up for a new car :)
    • Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more
    • I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
    • You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
    • Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
    • Yes correct, the guide coat is showing low spots, in this instance the low spots are pin holes. I agree wetting the areas makes it more visible (but you can see it's there before you wet it as well lol).  Once the panel is flat, the guide coat will be gone
