Hey everyone is there anyone/anywhere that sells the airbag harness to get rid of the airbag light once aftermarket seats are installed? If not I'll just try a 2ohm resistor, would prefer a neat plug if possible though. I've seen posts about NISMO making a harness, can't find anywhere actually selling them though.
TIA
https://www.sau.com.au/forums/topic/462489-airbag-light-with-aftermarket-seats/
Yes you will get an error, and yes the correct resistor will clear the error.
I assume it's not in an 1993 R32 Skyline GTST, its probably a 5ohm resistor if it's M35 or 2.7 for C34 but I'm not certain
I have been looking for the cancellation plugs myself, they are sold with Bride seats. I need a pair for a V35 but getting parts from Japan is hard with the language barrier. Nothing suitable on Yahoo afaik.
The M35 and V35 should be the same resistor as the G35 or 350z, so look up what they use.
Yea it's an M35, R32 was my old car
I had a quick look at the 350Z pages the other day and I think they said 2.2ohm or 2.7ohm, will have more of a look.
Have you tried Jesse Streeter? He's been good at tracking down random parts for me.
  • 3 weeks later...
Done a bit of reading up on this, and found this thread. Wondering if the DIY in the bellow link would work with our M35's
http://g35driver.com/forums/audio-video-electronics-diy/158005-diy-cancel-airbag-light-proper-way-07-weight-sensor-bypass.html
A shame the pics no longer work. I'm going to have a look at my OEM seats and have also asked amayama if they can get NISMO airbag harnesses plus I'm going to look into the 2.2ohm resistor, see which one works out best/easiest.
I have a spare nissan yellow plug if needed. I installed one under my passenger seat as it was hard wired and sourced 2 for my 350z seats. Its a simple install but still need to solder and heat shrink. You will also need to do the airbag light reset procedure to clear light.
Edited by joshm35
I may end up taking you up on that offer, cheers. Soldering and heat shrinking I can do. Thanks
  • 4 weeks later...
Success! The 2.2ohm resistor for each seat worked. No more airbag light. I just did it this afternoon, will keep an eye on it but don't see why it should come back.
Nicely done!
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
