Hi all,
I’ve owned this car for a few years now, barely drive it anymore and think it’s time for someone else to enjoy it. I had to fix a few things mechanically when I first bought it as it was starting to show its age, particularly in the steering and suspension bushes as well as some weeping front seals. I’ve ended up with a car that turns and stops properly, doesn’t leak oil and is very reliable. The car came with a pretty good record of maintenance and a few junk parts that I have since replaced. Cosmetically it’s still a little rough around the edges, the body is pretty straight with a few scratches, its had a respray at some point in the original colour and there are a couple of bits or rust starting to show under the drivers side rear window and in the spare wheel well. Interior is original with the usual standard features, clock doesn't work, bubble in the dash and B pillar trims coming away. Anyway, here’s some details and photos.
Engine and gearbox:
Internally stock rb26 with long nose crank
Apexi power FC
HKS 2510 turbos
Nismo AFM’s
Nismo fuel reg
Nismo Twin plate clutch
N1 oil pump (less than 1000km old)
Trust Type R BOV recirc’d
HKS 100mm intercooler and hard pipe kit
HKS big mouth Stainless dump pipes
RSR twin 70 to 80mm front pipe
Sard 800cc injectors
Splitfire Coilpacks
Blitz Dual SBC boost controller
Ross Tuffbond harmonic balancer and modified power steering bracket to line up the belt
Gates adjustable cam gears
K&N Filter in factory airbox
Metal Cat
3 inch exhaust with big RSR mid and rear mufflers
Walbro 500hp in tank fuel pump
Genuine Nissan timing belt, new tensioners and seals installed less than 1000km ago
Suspension and Brakes:
BC Coilovers
Full Hicas delete (all lines and solenoids)
Drift Works Hicas Eliminator and adjustable toe arms
Drift Works adjustable rear upper control arms
Subframe lock collars
GKTech Front roll centre adjusters
Tuneagent adjustable front castor rods (less than 1000km old)
Interior and Exterior:
Nardi Steering wheel with HKB boss kit
Nismo Gear knob
HKS boost gauge on A pillar
2wd/4wd controller
East Bear copy skirt extensions
BBS LM 17x9 +20 wheels and 255/40-17 AD08 tyres
And the air conditioning works.
Looking for $20,000 ono as it sits.
Rego til July 1st
Located in Campbelltown NSW
Contact via pm
https://www.sau.com.au/forums/topic/462496-syd-fs-1994-r32-gtr/
could be a gem at the price. looks ok from the pics.
Leakdown and then put the ears on it
3 piece Nismo/N1 side skirts and BBS rims
its like getting a few chips with your takeaway :)
Nismo Gear knob
2wd/4wd controller
Not N1 side skirts as it seems.
East bear copies hmmm. 3 piece and all
at a glance they fooled me :(
I couldn't see the east bear copy extensions when I looked - Doh!
I was obviously looking at them the whole time
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
