Looking to sell my 1993 R32 GTR. Located in Canberra currently has 3 months rego
It's a dark grey with a built 2.6L by CRD and single turbo conversion. I'm the third owner since it was personally imported (Green plate).
Mods list includes:
Forged Pistons
Nittos rods
ARP bolts etc
Mild ported head
Tomei 260 cams
OS Giken cam gears
Nitto oil pump
HiOctane 9L sump
HiOctane catch can with -12 speedflow fittings
Nitto rear drain kit
Nismo mounts
Hks intercooler
Trust oil cooler and filter relocation kit
Power FC
PTE6266 turbo
Trust dual intake with dual z32 afms
GCG manifold
3.5" dump
3.5" dual muffler exhaust (nice and quiet)
60mm turbosmart gate with screamer pipe
Nismo coppermix twin comp clutch kit
Defi gauges
Nismo front strut brace with master booster stopper
HKS rear strict brace
HICAS delete bar
Rear solid diff bushes
Some adjustable front and rear arms
CD player
Good condition interior for its age
Carbon radiator shroud (genuine garage defend)
Carbon exhaust cover
I also have 2200cc injectors that need to be installed to convert the car onto E85, a nismo thermostate and carbon head light intake of events.
I'm chasing $29,000.00 obo. The car will be sold with 3 months ACT rego.
post-63013-0-05057800-1453810441_thumb.jpegpost-63013-0-05057800-1453810441_thumb.jpeg
post-63013-0-44379500-1453810504_thumb.jpegpost-63013-0-44379500-1453810504_thumb.jpeg
  • Like 1
https://www.sau.com.au/forums/topic/462503-1993-r32-gtr/
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
