My R32 with RB25DET is having Power steering problems.
The Hicas Light is intermittently flashing at times and the power steering is grinding each time the light flashes. Im really worried about this and im hoping its nothing major. It seems like a broken PS pump, but sometimes, like when the car is sitting idling, the Power steering is FINE, no nosise, no grind no light.
I had my stereo installed today - could an Earth wire be affecting this. Is it anything to do with my battery.
Ive put more Power steering fluid in it and its not doing anything. The belts seem fine as well.
Im so scared ppls. Ive just spent my last penny getting this car and this happens I really hope its nothing major.
https://www.sau.com.au/forums/topic/46251-power-steering-playing-up-plz-help/
  • 1 month later...
Thanks for replies....reason I didn't get back was because I have been working on the prob. Rang local expert on P'steer and he said first up pump buggered (typical of "experts" replace first...then have a think about it). Explained tried 2 pumps then he suggested:
1. jack up car
2. With engine off - turn steering back and forth SLOWLY 5 times
3. Try again.
Expert said P'steer system is SELF PRIMING and that one of the HP hoses is a return line. Withthis in mind I also cracked both hoses and let foamy fluid out (with engine off).
Tried again and it WORKED!!!!! No noise.
On HICAS - the 2 lines going to the rear rack don't appear to be re-circulating (no return line?) AND there are 2 bleed nipples on the rear rack. IF the HICAS light comes on, there may be air in the rear lines. A good bleed may fix all those flashing HICAS lights.
Thanks for replies....it was my first thread.
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
