For sale: please just text/call me 0414596256
4" stainless r32 exhaust dump pipe back straight through just a cannon at the back (suits precision 7675/GT42 high mount turbo)
Steam pipe brae manifold, dual tial 44mm waste gates with screamer pipes, 5" intake pipe and filter included + braided lines (everything Except turbo)
$3000
All V band joiners included
R32 Shockworks fully adjustable coilovers $1200 near new!!!
Rb26 fresh painted blue cam and valley covers with tomei plate $500
-have modified dash fittings can come with braided line and catch can text me for photos and info
Tomei piston oil cap $80
R32 GTR genuine indicators $150 mint condition
Jun rb26 oil pump $1000
Rb26 CAS $70
Rb26 ignitor $90
Arp head studs $300 used
Turbosmart race port BOV $300
Rb26 sump extended capacity with tomei baffle 8.5L + oil pickup to suit with
Rb30 block gtr adapter plate to fit sump to an rb30 block. Most fixtures included $2000
Gk tech rb fan with rb26 hub $100
AME 18x10.5+15 almost new wheels and Achilles 123 semi slicks full set $2500 wheels and tyres just 500km old
Cusco 21 point full r32 coupe roll cage powder coated grey still new only trial fitted $750 (doesn't go through dash)
R32 engine damper $80
Aftermarket Industries e85 fuel system, surge, 3x walbro 460 pumps and a lift pump with modified r32 gtr fuel assembly braided lines wiring and relays (rrp$2500) $1200
Located Gold Coast can freight auswide no problem 0414596256
post-44496-14538621283565_thumb.jpgpost-44496-14538621965011_thumb.jpgpost-44496-14538622152397_thumb.jpg
post-44496-14538623525241_thumb.jpgpost-44496-14538624793425_thumb.jpgpost-44496-14538628131218_thumb.jpgpost-44496-14538628508433_thumb.jpgpost-44496-14538628756996_thumb.jpg
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
