Morning SAU'ers!
So I've done a good two hours of reading old forums and Google researching, gathering info on replacing my panel filter for a pod filter with heatshielding and just wanted a fresh opinion and some solid advice on a few things:
The kit I'm looking at: http://www.ebay.com.au/ulk/itm/131506420269(from JustJap)
The heatshielding I'm looking at: http://www.ebay.com.au/ulk/itm/201497303357
- Why mod? It's my first skyline (2000 GT-T), and basically first car I've started to tinker with and honestly, I really enjoy it. I'm 26 and never really been mechanically minded but ever since the purchase and some of the involvement/advice I get on here, it's now a dedicated hobbie. I've also read a bunch of panel v pod forums and I want to see if there's any difference in the two.
- Also, wanting to know how to go about installing a dedicated cold air intake that is directly exposed to the pod (someone mentioned piping from under the car to the pod)
- The legality of this as Vic law states one intake mod only but my turbo is factory so it doesn't/shouldn't count? I'm also fully licensed
2000 GT-T running stock boost, unmodified apart for the strut bars and the Splitfires I'm about to fit this weekend.
Any advice is welcomed! (:
https://www.sau.com.au/forums/topic/462544-air-intakepod-advice/
Cold air which I've done.
That pod kit is expensive and no doubt you'll want a hard intake pipe once you start adding power so it becomes redundant to buy it. Those 'heat shield' are useless. Make your own.
There's plenty of how to on this forum. Just type in things like cold air box SAU into google and check images etc
There's many things to mod. We all like doing so and understand the fun in it.
Just... the airbox is pretty much something you never need to do, essentially pretty much ever!
Have fun installing the next bit on the modding adventure :)
yeah only do pod if you want to change the induction sound and the look under the hood. cops love to see pods because it means mods to them which means defect potential..
No performance gain, just a personal styling thing. so your choice to do it or not, don't let anyone tell you one way or the other =)
K&N also do good pods.
Same with cold air intake piping, very little gain, and not usually noticeable,(maybe more at high power), so again only a personal choice.
I don't 'know' about vic law, but not likely to be an issue as its not really part of the intake system, only directs air to flow into the engine bay.
However, the above CAI requires you to use a FMIC which does not return through the stock holes, which frees up the space.
The heat shield is less a heat shield and more about looks again, and keeping things tidy. Also looks better for police, and helps keep the pod secure which is one of their problems with them.
Welcome to the world of import modding! You have many many many more hours/days/months of searching and reading to do, so learn to use the search functions and get comfy =)
^ this
Thanks guys for the feedback. Sounding a bit more cosmetic/personal opinion the more I read into it. I'm just taking baby steps at the moment so I might give it a crack.
Wut. Shielding heat from intake is good.
I agree and plenty of graphs will back up that the stock airbox is fine. But! A few tuners have had gains with a pod in a proper box.
The only reason to use a pod is if you want more power and have to change to a hard intake pipe and you want to do it cheaply. And you can diy.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
Ă—
Ă—
