I was looking at this kit - https://rossperformanceparts.com/product/nissan-rb26-r33-r34-gtr-metal-jacket-harmonic-damper/
But read a number of reports about issues with PS belts being thrown.
A friend of mine works at Ross (came over when Omega bought them out) and claims they fixed an inherent design issue with the wrong offset on the pulley grooves when they came onboard.
I'm wondering if anyone has bought and used one of these in recent times and can report back on how you've found it?
They're mint now. Killer product and customer service is better than ever. I'm using their gear on my new build too.
So you have experience with it, or you're just talking up all the shit people gave you for free?
  • Like 1
I had two for the last ten years.
The early one still never through any belts, and the new one has the trigger wheel setup on it and it is all good too.
Great product, bit pricey for their trigger kit, but super well made.
People actually using them need to pipe up as it all feels hit and miss. I am holding off buying new OE as long as i can in case these things become a proven setup
As per the original post. Interested in people who have recently bought, not bought one years ago.
Just to clarify.
so you'd buy a part that proven to be f**ked because they "probably should" have fixed the problem now?
No.
I've already decided to leave the stock one.
Given there's clearly been some discussion on this here, I didnt think it would hurt to continue the thread if there was new info at hand.
Have you considered chilling out a bit?
My Ross damper was purchased in the pre Omega technical days. We recently pulled the engine to fit a bigger sump and open up some clearances only to find the balancer has chewed up the nose of the crank. Car has only done two dyno sessions and one light shakedown. Bearings looked good fortunately but we have some work to do to clean up the front of the crank.
The guys at Omega have the balancer for inspection at the moment. Have to say so far they've taken it seriously and aren't doing any of the finger pointing you normally expect in this sort of situation. Sounds like there have been a number of significant design improvements since Omega took over as well.
Whether I'm game to put it back onto the engine will depend on what happens next.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
