Up for sale is My M35 Nissan Stagea. Car has just had 6 months rego put on it as well as a brand new set of tyres. I have owned the car for over a year now and have performed the following modifications.
KMs: 13* ***kms
6 months rego
Modifications:
Lenso 19inch wheels
Full sound system
Hypergear SS2 highflowed turbo
Full aftermarket exhaust ( Scottys dump pipe , 3 inch stainless with high flowed cat)
K&N Filter
Greddy emanage ecu
Bosch 1000cc Injectors
Walbro Fuel Pump
HDI Intercooler
Turbosmart BOV
Car makes 263rwkw on 18psi. Car is tuned to run Caltex E85. Performance parts fitted and car tuned by DVS Jez. Car has potential for more if u so please would just need a boost controller and a re tune. Car is a good mix of practical daily with a bit of go. Car does have a few small scuffs and scratches but other than that is in a decent overall condition.
In no rush to sell but I chop and change cars a lot so would like to get into something new.
Cash is king and is preferred.
However I will consider swaps. I would be chasing something either turbo or V8. My preference is and import something like Toyota chaser , LS400 , Celsior , Aristo , Nissan Cima , Cedric , Gloria , Crown , Century etc etc.
Will also consider something luxury BMW , Merc , Lexus etc. Only holden ford etc I would consider swaps for is a VL turbo.
Swaps MUST be automatic and be big enough to fit a child seat in rear.
Please text if interested as my work and family are all over the place.
PH: 0404 519 365
Price: $11990ono
12011335_1130646950297308_82708067862615
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
