If NSW, something <15mm difference in diameter from the stock R32 tyres, which are 225/50/16 = 631.4mm diam. 245/35/18 and 255/35/18 look ok, but the standard R34 tyre size (245/40/18) is too big - its 20.9mm different at 653.2mm diam.
https://www.sau.com.au/forums/topic/462587-r34-gtr-rims/#findComment-7674973
I've been through a few RBTs and even pulled over on the freeway in ACT for a drug test. The police never commented on my ride height (was a bit too low before for my liking), my wheels nor my exhaust.
Went from BNR34 wheels to LMGT1s, ran minimum 265/35/18 tyres. Of course, my car looks fairly standard and not some drifter/stancenation.
https://www.sau.com.au/forums/topic/462587-r34-gtr-rims/#findComment-7677525
265 tyres on those wheels won't be an issue and no need to run extra camber to makes them clear either
I run a 265 on a 18x9.5 +22 on mine and I have the wheels sitting very up right and they don't scrub at all, I also haven't rolled the lips on the guards either
  • Like 1
https://www.sau.com.au/forums/topic/462587-r34-gtr-rims/#findComment-7682946
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
